dash labels.. how do i apply them ?
Hi, I have a full set of dashboard labels to apply... how do I do it ??
I thought they were pressure transfer...no
I thought they were water transfer... apparently not...
So how do they work ?
LaikaTheDog - Third Gear
Depends on what you have. I purchased a set that were dry rub that you lay in place on a varnished surface and rub to transfer the letters. You then top coat the whole dash to seal the letters under the finish (same as factory). I also had a set from RDEnt that were just cut and stick on. You placed these on the surface of the final dash. They went in the bin quite quickly.
- Davefettback
