Re: Battery brand from the factory
trw99 wrote:I suspect this is the photo to which you referred, a 1967 FHC kit, laid out at the factory and very clearly showing the Exide battery.
This was the picture I had in mind. Good to see the old memory hasn't given up completely.
As pointed out above, there aren't that many bits to put together. Clearly Dr Hammerton was a bit of a novice at this if took him most of the weekend to put the kit together.
