Battery brand from the factory
There is a picture (that I can't now find) of all of the contents of the Elan 'kit' spread out in front of the car. I believe it was an in-period advertisement illustrating the relatively few components required to complete the car. From memory, the battery was part of the display of parts and was an Exide battery.
I could of course be wrong.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Not sure about earlier fitment but in the UK I think from memory they were Exide "Supreme" around the time of the Sprint........I have an idea that the "Supreme" model came out later on in the 60's and that the earlier cars had an "Exide" battery but I don't know for sure which model........I would really like to know myself if any one has the definitive answer? I wonder if it lists the model in an early parts list? I will try to find out .......
- Pastapesto
MarkDa wrote:Have you tracked down a battery with the period look (non sealed) to put the sticker on?
No, I haven't. Might be quite expensive. For now, and for a battery that has only one side that's seen (trunk
mount), I'll peel off the modern sticker and replace with a vintage sticker. The battery is too new to replace
right now. But...... I like your idea for my next step.
Thanks for the picture! That's what I'll be looking for, or 'reproducing' from a modern battery.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
I suspect this is the photo to which you referred, a 1967 FHC kit, laid out at the factory and very clearly showing the Exide battery.
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
Greg, I believe the anti-sizzle gear stick was introduced during the Series 3 production run, perhaps early 1967. Having said that, Robinshaw & Ross attribute the kit photo to mid 1966, but have a question mark against the introduction date.
trw99 wrote:I suspect this is the photo to which you referred, a 1967 FHC kit, laid out at the factory and very clearly showing the Exide battery.
Hmmm, that kit car will be rather noisy with only half of the exhaust manifold and no Y piece.
billwill wrote:trw99 wrote:I suspect this is the photo to which you referred, a 1967 FHC kit, laid out at the factory and very clearly showing the Exide battery.
Looks like it has the y piece attached to the 2 down pipes which will have connected to the 4 to 2 cast manifold of the time which I am not mistaken will be on the far side of the engine and not visible
