Lotus Elan
OMG what have I done?? (New dashboard)
PostPost by: Robbie693 » Tue Oct 08, 2019 11:25 pm
Hethel_Haus wrote:A couple of questions related to the dash on a '73 +2S 130/5 (RH drive). The dash has a securing bracket at the bottom and it has an electrical component attached with the wire connections cut. Wondering if it is a "Microswitch"? FYI all of the lights worked on this car before I started dismantling. Second question is related to the dashpad. The front edge of mine was glued to the dash making it real difficult to remove. Looks like from other dash photos on the forums here that the two pieces should be separate. How was the dash assembly fabbed at the factory?
Cheers!
Appleton, WI
Sorry to drag this thread back a bit but I thought I should mention - those angle brackets on Steve's dash are original fitment, they attach to the body via the door switches and secure the corners of the dash by bolting to the plates that can be seen at either end of the back of the dashboard...
Robbie
Robbie693
PostPost by: JonB » Wed Oct 09, 2019 7:27 am
Oh right.
On my car there are brackets like that, but they don?t run the full length of the dash side. They?re about six inches long and bolt to the brackets and the courtesy light switch. There?s one on each side.
PostPost by: Robbie693 » Wed Oct 09, 2019 8:11 am
Yes that sounds about right - I think Steve's picture was misleading in that it makes them look larger than they actually are.
Presumably you had to transfer the mounting plates to your new dash?
Robbie693
PostPost by: JonB » Wed Oct 09, 2019 10:10 am
Yes, I did - along with all the other hardware. It took a long time, because I was being very careful to ensure switches were centred and all the other bits and pieces. Unfortunately I wasn't careful enough; I drilled a pilot hole all the way through the veneer and varnish, and scratched up the glove box lid while filing its edges down. :evil:
PostPost by: Robbie693 » Wed Oct 09, 2019 11:21 pm
Well it looks ace anyway - the detailing on the lettering is the best I have seen on a supplied dash. I imagine the small mistakes you made will fade in your memory and won't be visible to anyone else anyway. Just don't point them out trooper! :lol:
Robbie693
PostPost by: JonB » Thu Oct 10, 2019 7:54 am
Actually, the lettering is not printed on the dash. It?s all stick on labels, not that you can tell unless you look really closely.
PostPost by: JonB » Sat Oct 19, 2019 5:23 pm
So I was feeling pretty pleased with myself..
fd2bf75c-ae4c-46ff-a8c9-fe63ef2fb6fc.jpg and
Nice shiny new dash.
Until I noticed this:
img_6122.jpg and
Arghhh!
..and this..
img_6119.jpg and
Arghhh!
Dust from the dash fettling around the radio opening had got inside the voltmeter, and the wires had fallen off the back of the indicator switch. We can't even blame Lotus as they are Smiths / Lucas parts. :roll:
So, out with the voltmeter and a bit of surgery on the indicator stalk.
img_6128.jpg and
Better. Much better.
And some work in the famous "Lotus position" had me sorting the loom out on the right hand side of the tunnel.
img_6129.jpg and
All tucked away neatly.
I'm now looking at the ignition switch and how it fits with the lower padded trim - or not as is the case with mine. The column assembly has much scope for fettling, so I'll be down there with a spanner soon!
PostPost by: JonB » Wed Feb 26, 2020 4:25 pm
IMG_6283.jpg and
PostPost by: MarkDa » Wed Feb 26, 2020 5:38 pm
Very smart - worth all the effort I'd say :D
MarkDa
PostPost by: SENC » Wed Feb 26, 2020 6:08 pm
looks great!
Henry
69 Elan S4
65 Seven S2
PostPost by: JonB » Wed Feb 26, 2020 7:16 pm
Thanks!
Carpet’s a bit tired but let’s call it “patina”. :lol:
Previous
