OMG what have I done?? (New dashboard)
PostPost by: JonB » Wed Aug 28, 2019 8:15 pm
I had a bit of a slow day today so thought to go into the garage to make some progress. Something small and straightforward - like pulling the Kienzle clock out and seeing if I could repair it. However, one thing led to another...
img_5739.jpg and
img_5740.jpg and
img_5741.jpg and
img_5743.jpg and
Ooops, I seem to have pulled the dash out!
En route, I also replaced the steering column bushes.
PostPost by: JonB » Wed Aug 28, 2019 8:27 pm
Using a Brother labelling machine I labelled up all loose wires, but left the switches and fuse box connected, preferring to unscrew them from the back of the dashboard. I will pull them off the loom, but only after labelling all the connections.
img_5744.jpg and
Spot the labelling machine
I'm delighted with the little labeller.
Now, as usual I took very few pictures, trusting instead to the labels.
Later on I turned my attention to the broken clock. It looked like the solenoid was burned out - certainly it has seen a bit of heat - but in the end I just needed to resolder a joint that had come loose.
inkedimg_5745_li.jpg and
Then some testing on a dodgy test setup..
img_5746.jpg and
Seems to work - ticks along and auto winds, but the hands aren't moving. It was working before.. I must have knocked it out of kilter. Will need a good fiddle I expect.
img_5742.jpg and
Big thanks to Paul for assembling my car!
PostPost by: JonB » Wed Aug 28, 2019 8:31 pm
Hmm, a closer look reveals that one of the plastic gears has been partially melted, so I think this is the end for the clock. :cry:
PostPost by: richardcox_lotus » Wed Aug 28, 2019 8:49 pm
3D printing ?
'72 Sprint
PostPost by: MarkDa » Wed Aug 28, 2019 11:12 pm
Now you've got it all apart there must be something else you didn't know you needed to do!
After all you did a full suspension rebuild and chassis repair in response to getting the indicator cancel to work last year :D
MarkDa
PostPost by: JonB » Thu Aug 29, 2019 7:29 am
:lol: :lol: :lol:
Actually, it wasn't a full suspension rebuild, but a refresh of the bushes all round and trunnions. To be fair, I knew this had to be done, just as I knew a new dashboard and heater overhaul was needed. I have to say, dashboard removal has been much easier than I thought it'd be, especially pulling the ambient temperature gauge out which I fretted about incessantly. In fact, so far the only unexpected work was the knackered rear bearing and trip to Peterborough, so I consider myself lucky (so far)!
By the way, since Peterborough the indicators have not self cancelled, because when they did the tracking they didn't ensure the steering column was in the central position. I've put up with it since, but I'll sort it when the column goes back in.
So this morning I will pull the heater box... what horrors await??
PostPost by: JonB » Thu Aug 29, 2019 7:31 am
richardcox_lotus wrote:3D printing ?
I doubt a PLA type printer will have the precision to do this sort of work, and I don't have access to one, anyway (or the required skills). Good idea otherwise..
PostPost by: MarkDa » Thu Aug 29, 2019 7:50 am
Clocks available on eBay - one just sold for ?16.
Guaranteed working aren't cheap!
MarkDa
PostPost by: MarkDa » Thu Aug 29, 2019 7:55 am
Jon
As a matter of interest how did you get the column bushes out?
I have more play than I should and bought replacements but couldn't shift the old ones.
Fortunately my MoT man is fairly laid back so it's not been a problem but I'd like to them right.
MarkDa
PostPost by: JonB » Thu Aug 29, 2019 8:35 am
Easy peasy.
  • Remove column from the car entirely (and take the ignition barrel off).
  • Locate the rubber pegs in the shaft, then drill them out.
  • Remove the indicator self centering clip (ah ha!)
  • The steering column shaft should slide up and down inside the casing, and stop. It's the locking collet hitting the old bushes.
  • Stand column upright on a Workmate with the steering wheel end down. You need to have the jaws of the Workmate open enough to let the shaft go through.
  • Use a wooden mallet to tap the shaft down. This should drive the top bush out.
  • Remove shaft, turn it over and reinsert it. Slide it down so that it stops on the bottom bush.
  • Place the column on a block of wood on the floor, upright, and drive the bottom bush out with the mallet.
To fit new bushes:
  • Lubricate bush with detergent and push into bottom end of column housing, ensuring the pegs line up with the holes in the housing.
  • Use the shaft to drive the bush into the housing. You might need to press the leading edge of the pegs in once they catch on the housing edge.
  • Remove shaft and insert it in the top of the housing, right way round (this means, with the steering lock collet nearest the top of the housing). Slide it down.
  • Lubricate the second bush with detergent and insert into top of housing, ensuring the pegs are aligned with the holes.
  • Use a suitable drift to drive the top bush into the housing (in my case, a M10 garden bolt with a domed end).
  • Slide inner shaft up into position and refit the indicator self centering clip.
Looks like a faff but in practice it is common sense. Just remember to refit the shaft prior to fitting the second bush, and treat the housing carefully - it's very thin and can easily be damaged.
PostPost by: MarkDa » Thu Aug 29, 2019 8:56 am
Thanks Jon
I think the key is drilling our the fixing lugs.
I was worried about bashing it too hard given the fragility of the tube.
I'll try again in the winter.
MarkDa
PostPost by: vincereynard » Thu Aug 29, 2019 9:37 am
JonB wrote:By the way, since Peterborough the indicators have not self cancelled, because when they did the tracking they didn't ensure the steering column was in the central position.
They did the tracking! :shock: Did you remember to mark the nose of your car with "FRONT" to give them a clue?
PostPost by: JonB » Thu Aug 29, 2019 12:12 pm
Well, you drove it. I've not touched the tracking since, and it feels OK. He said it was set at 3mm toe in (possibly per side, can't recall). Just a pity they didn't check the self cancellers.
Meanwhile...
I've pulled the heater box out. As usual, the foam and lip rubbers are all perished and crumbly, but the general condition is pretty good, especially the radiator. Quite happy!
Anyone know where to get lip rubber?
PostPost by: vincereynard » Thu Aug 29, 2019 1:35 pm
JonB wrote: Just a pity they didn't check the self cancellers.
Maybe they did but disconnected the handbrake instead? :?
PostPost by: john.p.clegg » Thu Aug 29, 2019 4:44 pm
Sheet neoprene from Fleabay and a pair of scissors..
John :wink:
Next
Users browsing this forum: No registered users and 44 guests
