Temp/Oil P gauge removal
I'm biting the bullet and removing the dash to fix myriad issues. It's almost out...
How do I remove the temp sensing tube from the back of the temp/op gauge?
For extra credit - how do I get the temp and chock cables off the dash as well?
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
steve lyle - Third Gear
The gauge, piping and sensor bulb screwed into the head by the thermostat form a single sealed unit.
You have to remove the bulb from the head and carefully feed the bulb and piping through the bulkhead wall and the hole in the dash to remove the gauge.
The bulb fitting often corrodes, and it is easy to destroy the bulb or fracture the piping in the process of removal.
While it is possible to repair a damaged unit, it isn't easy. Be prepared to buy a new one.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
steve lyle wrote:For extra credit - how do I get the temp and chock cables off the dash as well?
Disconnect the rod/cable from the temp control valve / carbs, then pull out leaving the sleeve still there. Use a pair of needle nose pliers or special tool unscrew the bezel nut. You can buy a tool like this:
Or I have the cheaper version made from a short length of copper pipe.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 05 Elise, 2005 MiataSpeed Turbo
tvacc - Coveted Fifth Gear
tvacc wrote:I have a fix posted on http://www.lotusowners.com for the oil pressure gauge. Simple cheap fix.
Tony
Main snag with this is that we can't seem to get inexpensive bulb-capillary temperature guages in the UK. Looks like we would need to buy one from the USA.
They only cost $15 or so in the USA. Get a group buy together, send me the order and I will buy them for you and ship them over.
Tony Vaccaro
From Advance Auto parts. $17.99 plus 8.75 percent tax.
Tony Vaccaro
pharriso wrote:steve lyle wrote:For extra credit - how do I get the temp and chock cables off the dash as well?
Thanks, Phil. But it looks like my cables aren't held on with any kind of screwed nut. Looks like a locking ring of some sort - maybe I just have to grind or cut it off?
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
pharriso wrote:No.no.no.... the nut is on the front face down the tunnel...
Maybe someone can post an exploded view...
Aha - the lightbulb just went on. No need for an exploded view, I think I've got it.
Thanks!
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
I have used a needle nosed pliers to get that nut off.
Tony Vaccaro
When you loose the big brass nut holding the temp bulb into the head HOLD THE BULB ON THE FLATS WITH A SPANNER WHILE LOOSENING THE NUT......if you do not the chances are that you will twist the capillary pipe and break it then a repair or new gauge will be needed!........if you get a hospital smell (either) then you have broken it.
