Accidentally overheated my engine!
Still a bit new to Elan ownership, and finally getting to drive the car more regularly.
My car has the cartridge-style water pump and an electric fan instead of a mechanical one.
Was driving on a warm day and apparently I accidentally turned the electric fan switch off, because by the time I got home and noticed what was happening, the temp gauge was a bit beyond the highest mark!
I've since driven the car and it's seemed fine -- didn't notice any milkshake in the oil and the coolant levels seem normal. But is there anything else I should be looking out for?
- monkeyodeath
Are you sure the fan was switched off? They are usually controlled by an otter switch in the radiator, with a manual switch to override the otter in heavy traffic to bring the fan in a little earlier. That way you can't inadvertently switch it off.
If the water and oil is staying in it's respective areas you should be OK!!
My fan is manually controlled. You learn to turn it on when you live in Texas. My stupid question tho, is does anyone overheat their engine on purpose?
Fred Talmadge - Fourth Gear
nobody, except maybe DONald would deliberatly overheat or leave the fan off fred, ----- BUT if you'd seen lots of white smoke coming from the front, you at least know: keep that ...... fan on - you probably have a45amp alternator, so youll always get home sandy
- el-saturn
Fred Talmadge wrote:My fan is manually controlled. You learn to turn it on when you live in Texas. My stupid question tho, is does anyone overheat their engine on purpose?
lol, I guess the title should have been "I accidentally left my fan switch off!".
- monkeyodeath
Elanintheforest wrote:Are you sure the fan was switched off? They are usually controlled by an otter switch in the radiator, with a manual switch to override the otter in heavy traffic to bring the fan in a little earlier. That way you can't inadvertently switch it off.
Pretty sure that this is an entirely manual fan. The engine was really hot but the fan did not come on until I hit the switch.
Thinking I should install a temp switch, however. Doesn't make sense to run the fan when it's not needed.
- monkeyodeath
Some could suggest that having a manually controlled fan - in Texas - is even more stupid than your question.
I would NEVER suggest such a thing but others may.
Any every time I have felt the need to supplement the cooling in these cars or similar vehicles I have always done it in such a way that it is automatic with - if as and when needed - a manual override.
- Slowtus
Is the typical setup a probe switch that's inserted in the radiator fins?
- monkeyodeath
I realize that this is overkill to some. But my car has a Cosworth BDP engine that's worth a fortune. So wanted to be careful with this design.
When I was planning the fan setup in my car I realized that with a single fan or a single controller, any failure in the fan system could easily cost a motor.
So I did the fan setup with two fans (9") each with a separate controller. One uses a Hayden PWM controller to keep the noise down (starts at 170F). The other uses a standard temp switch (195F) and a relay.
The car runs at 180 all day. I haven't had it out on a day over 80ish def F yet. But I also know that it's not even using the second fan yet.
One thing I want to add is an idiot light for the temperature. Cheap insurance.
-Kyle
-Kyle
'70 S4 Elan - Cosworth BDP & Spyder Chassis
'62 S2 Super Seven Cosworth
- disquek
monkeyodeath wrote:Pretty sure that this is an entirely manual fan. The engine was really hot but the fan did not come on until I hit the switch.
The usual way to install a manual switch on the cooling fan motor is to force it on, not to shut it off : maybe there's been a mistake in the connections (e.g. the thermally controlled ground could be shared with a manually controlled ground so that either would start the fan - a relay can be useful depending on fan motor rating).
S4SE 36/8198
nmauduit - Coveted Fifth Gear
monkeyodeath wrote:Is the typical setup a probe switch that's inserted in the radiator fins?
There's a few options....
1] Have an adapter brazed into the radiator (usually near the top hose) and fit a sender unit- you should be able to pretty much choose the operating temperature for this... if you fit a modern sensor
2] fit an adapter into the top hose (you cut out around 1" of the hose out (if your top hose is just rubber)... this can easily be reversed (for example see revotec)
3] OE was often an otter switch fitted into a grommet (hole in the rad)
4] a small metal bulb with connecting tubing is inserted into the top hose at the radiator (this will usually have a controller attached... this is how Kenlowe did it in the 1980s).
usually the sender will feed a relay which operates the fan, the dashboard switch would be wired in parallel to the sensor, it's a failsafe if the sensor fails or if you get a bit nervous on a hot day.
HTH
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
Lately I've seen that the outflow side of the radiator (bottom) is the preferred place for the sensor as it's always covered in coolant (if the level drops). I don't like the sensors that stick into the fins, although they should work. I'm OCD. lol
These folks sell a wide variety of adapters that can be spliced into a radiator hose and can be had with various threads for sensors. I've bought several and always been happy with them. https://jagsthatrun.com/
-Kyle
-Kyle
- disquek
If it did not boil, you really didn't overheat it.
As to the finger waggers about a manual switch, I had several thermal switches fail, so I am more reliable than they are, so, enough
Check coolant now that it is cool, check oil content. Start, warm up, check again. Take it for a drive, check again.
No harm no foul
No harm no foul
- gus
Took the Elan on a nice, aggressive nighttime drive last night. Temps stayed around 80-ish. Coolant level this morning was at the top of the radiator. There was a small, dime-size bit of white milkshake on the oil filler cap, but none visible in the oil. So I'm going to try to relax!
As far as the fan switch, I think even just adding an indicator light might help, because it can be hard to tell if the fan is even on while the car is running, and the switch doesn't have "off" and "on" indicated. It's also located in a spot that's kind of easy to bump with your thigh. When I got the car really hot, I didn't realize that the fan had been switched off.
The PO of the car said he always had the fan on, never turned it off. Is this the best way to go? Is there any advantage to having a switchable fan with these engines, or do they generally need as much cooling as they can get? (I come from the air-cooled 911 world, where you stop the car if the fan stops moving!) I live in Los Angeles, so the car won't see much cold weather.
- monkeyodeath
