661 wrote:With your boot rubbers, is the round squashy section ( more rectangular in your case if memory serves) on the inside of the attaching profile or on the outside? My new rubbers have just arrived from R Dent who ,in my view, make the most accurate reproduction and I've dry fitted them with the round profile outwards.
Glad you like the video. Imagine how exited I might be when I finally fire up the engine
I fitted the boot seal with the squashy section to the inside. I didn't consider fitting it the other way because I was following how the old seal had been fitted. I got a comment on youtube suggesting that I'd be better fitting it the other way so the lock would clear it. I have tried it the other way and in principle it looks like it should work better with the squashy section to the outside, however it was putting quite a lot of force on the boot lid pushing it up so much that it was out of alignment with the bodywork. Maybe it would have been possible to put a weight on top of the boot lid to squash the seal down over time. Also now that I've cut it to fit on the inside it's too short to fit the other way around, so for those two reasons I'm stuck with it on the inside. It'll be interesting to know if the round seal works OK on the outside. My original seal was definitely more round than square.
Paul
