ignition key barrel
Tue May 14, 2019 7:18 pm
by Uboat
I lost the keys to my car, and I have turned my house upside down without finding them. So I guess I have to remove the ignition barrel and exchange it for a new one...
What is the easiest route for this? Do I need to remove the whole of the steering lock/ignition assembly? Or is it possible to get the barrel out in situ? As I need a new barrel, I don't mind using violence in the process as long as the assembly/steering lock is not damaged...
/Ulf
Re: ignition key barrel
Tue May 14, 2019 7:27 pm
by richardcox_lotus
I think it?s unlikely you will be able to get the barrel out without removing the lock. If it?s a steering column lock, there are 2 ?anti tamper? bolts that are designed to shear their heads when turned.
They may have been replaced over the years, but otherwise the advice is to remove with care.
Others who have done it may chip in
Richard
Tue May 14, 2019 9:28 pm
by wotsisname
May be worth nosing around on triumph forums ?
Tue May 14, 2019 11:36 pm
Lock barrels are designed so that it is only (relatively) easy to get the barrel out when you have the key.
Wed May 15, 2019 10:53 am
by LaikaTheDog
Your local locksmith can pick it in seconds with a jiggler , you can then remove it
Wed May 15, 2019 2:05 pm
by Uboat
Thanks for replies
Ok, I understand the ignition key/steering lock assembly is actually a Triumph item. Does anybody know from which car (I have a late Elan +2). Is it from a TR6? I have found similar, but not identical, parts from Triumph suppliers. Does anybody know if they are interchangeable?
/Ulf
Wed May 15, 2019 5:17 pm
Uboat wrote:Thanks for replies
/Ulf
I believe it is from GT6 Mk3 - Waso was the original manufacturer, replacements available here -
https://rimmerbros.com/Item--i-GRID008089
Thu May 16, 2019 12:43 pm
All in all you will probably find it less damaging to get a local locksmith to fit a new barrel for you.
Many barrels are standard sizes so you wouldn't need to go finding the external bits from other cars.
Ages ago I fitted my S3 doors with more secure barrels that came from filing-cabinet locks, these ones have tooth notches on BOTH edges of the key.
It was great fun one time when I left my car too long in a soho steet and I returned just as the Police were trying to open the doors with a massive bunch of keys. None of them fitted
Thu May 16, 2019 12:53 pm
by el-saturn
isn't ronnie scott's and a good jazz record store (moe's?) in soho?.......................luv it, been there at R.S. one time had scottish scallops as main dish and billy eckstines group, plus wifey-pooh sandy
before You drill...
Thu May 16, 2019 9:41 pm
by Emma-Knight
Try to find the Key Numbers in your documents. They are like "FS 123" or two letters, three Numbers. Baby Elans had two different Numbers , one for Ignition and Doors, one for Boot and Glovebox. If You could undo a door lock barrel, it might show the three digit number that You could order at the usual suspects, like Limora or so.
Anna
Fri May 17, 2019 7:26 am
by Spyder fan
If all else fails you may have to follow these instructions
https://www.lotusmarques.com/info/techn ... an-2-s1305I think that the replacement parts you need are listed here, perhaps somebody could confirm?
https://rimmerbros.com/Item--i-GRID008112See if there is an Auto locksmith near you, it may work out cheaper and easier to call somebody out.
