ignition key barrel
I lost the keys to my car, and I have turned my house upside down without finding them. So I guess I have to remove the ignition barrel and exchange it for a new one...
What is the easiest route for this? Do I need to remove the whole of the steering lock/ignition assembly? Or is it possible to get the barrel out in situ? As I need a new barrel, I don't mind using violence in the process as long as the assembly/steering lock is not damaged...
/Ulf
/Ulf
1974 Lotus Elan +2 130/5
- Uboat
I think it?s unlikely you will be able to get the barrel out without removing the lock. If it?s a steering column lock, there are 2 ?anti tamper? bolts that are designed to shear their heads when turned.
They may have been replaced over the years, but otherwise the advice is to remove with care.
Others who have done it may chip in
'72 Sprint
'72 Sprint
- richardcox_lotus
May be worth nosing around on triumph forums ?
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
Your local locksmith can pick it in seconds with a jiggler , you can then remove it
LaikaTheDog - Third Gear
Thanks for replies
Ok, I understand the ignition key/steering lock assembly is actually a Triumph item. Does anybody know from which car (I have a late Elan +2). Is it from a TR6? I have found similar, but not identical, parts from Triumph suppliers. Does anybody know if they are interchangeable?
/Ulf
/Ulf
- Uboat
Uboat wrote:Thanks for replies
/Ulf
I believe it is from GT6 Mk3 - Waso was the original manufacturer, replacements available here - https://rimmerbros.com/Item--i-GRID008089
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
All in all you will probably find it less damaging to get a local locksmith to fit a new barrel for you.
Many barrels are standard sizes so you wouldn't need to go finding the external bits from other cars.
Ages ago I fitted my S3 doors with more secure barrels that came from filing-cabinet locks, these ones have tooth notches on BOTH edges of the key.
It was great fun one time when I left my car too long in a soho steet and I returned just as the Police were trying to open the doors with a massive bunch of keys. None of them fitted
Try to find the Key Numbers in your documents. They are like "FS 123" or two letters, three Numbers. Baby Elans had two different Numbers , one for Ignition and Doors, one for Boot and Glovebox. If You could undo a door lock barrel, it might show the three digit number that You could order at the usual suspects, like Limora or so.
Anna
Anna
1965 S2
- Emma-Knight
If all else fails you may have to follow these instructions
https://www.lotusmarques.com/info/techn ... an-2-s1305
I think that the replacement parts you need are listed here, perhaps somebody could confirm?
https://rimmerbros.com/Item--i-GRID008112
See if there is an Auto locksmith near you, it may work out cheaper and easier to call somebody out.
Kindest regards
Alan Thomas
Alan Thomas
