high torque starter and solenoid removal
Hiya,
been a while since i've been here (block has been at the machinist for like six months geeeze).
anyway while it's not running i started thinking about wiring, I have a high torque starter and that means there's no reason for the starter solenoid other than as a big terminal.
Why don't people seem to remove the solenoid? it is heavy and not needed. Is it for safety reasons? I would imagine if you ran a big fat battery positive down to the starter there is a risk of it touching the block and bad cooking things would happen....but, it's also possible in many other situations.
what ch'all reckon?
happy new year
what ch'all reckon?
happy new year
36/6612
1967 S3 Coupe (left the factory in 66)
original rego PPC 8E
original owner B.M. Wetherill ..are you out there?
dgym - Third Gear
My s4 had a high torque starter and no solenoid, and was wired as you described with battery running directly to starter. The problem is the running the ignition wire directly to the starter can result in insufficient voltage to fully engage the pinion. I recommend leaving the solenoid in place. Mine worked fine for at least 10 years, and I have been over all the grounds, replaced starter, ignition switch, earth strap to engine... you name it. My conclusion is best to leave it wired up as intended. All the best, Dan
Following on from Dan`s observations, I suggest you check the current drawn by the starters internal solenoid. ( the smaller terminal )
On my starter it is about 6 Amps
If it is high you may not want that amount of current passing through the ignition switch.
You could of course fit a relay, but then you are making it complicated again.
I have left the bulkhead solenoid in and it takes two and a half Amps
Let us know what you decide,
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
Ditto
The above , leave the solenoid to do the low and high ampage to the starter , just connect the two together you also have some originality..
For years I've been concerned about the proximity of the solenoid to the rear carburetor, in the case of a frontal impact accident or maybe even the solenoid vibrating loose. I installed a high torque stater on my Super Safety a couple of years ago and the old lump solenoid excused himself and left the table and I feel much safer. Fire terrifies me!
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Thanks guys,
I should have mentioned that this car has a new custom loom that I put together not long ago. So the wires are rated higher and there are more fuses/relays.
I'm not worried about having to add terminals to get power to the fusebox and coil etc, I can do that no worries. I was thinking about something that both passes through the bulkhead and acts as a terminal, instead of the awkward way the battery positive cable routes through.
I'm also not worried about originality, that boat has long since sailed!
It's a fun exercise for me to lose weight, (on the car at least HAHA) and this solenoid appears to not be doing the work of a solenoid (as the ig switch is already going straight to the starter's inbuilt solenoid) so right now the solenoid is just dead weight. both the pos from the battery and the pos to the starter are mounter on the same bolt.
I guess my concern was more about safety from a short, as I will have a positive cable down near the engine block and under the carbs. But yeah it seems like something that probably happens on cars anyway without any more danger.
36/6612
dgym - Third Gear
My Plus 2 is set up as you describe. I used a terminal block approximately where the solenoid was mounted, with a large cable down to the starter so I didn?t have to replace the cable from the battery. I also installed a fusible link from the terminal block to protect the whole loom. The alternator main also goes to the terminal block, routed in the engine bay. The stock ammeter was replaced by a voltmeter.
Interesting to read about some of the concerns. Mine seems to work OK.
Stu
Plus 2
Stu
Plus 2
Stu
1969 Plus 2 Federal LHD
Hi Stu yes this is what I'm thinking and it's great to see someone who has done it.
I was going to ask about the voltmeter then realized I don't have one anyway!
cheers -Jim
cheers -Jim
36/6612
dgym - Third Gear
I left the solenoid in situ primarily to appear original and to allow easy backward install of the original type starter.
I realised an added benefit of doing so, is that your left with a convenient power source for your timing light / stroboscope. Keeping the big terminal was certainly a bonus as the timing light crocodile clip connectors were to big to attached elsewhere.
Peter
Peter
1968 +2 BRM
- Peter +2
I?d be tempted to remove the solenoid but fit a battery isolator switch there in its place, easy to access when working on any electrics under the bonnet, easy to access in emergency, just pop the bonnet rather than rummage in the boot (probably hidden behind all sorts if you are like me and carry a load of stuff in the boot).
You don?t have to have the solenoid if you have the reduced voltage coil, just a suitable feed from the starter terminal on the ignition switch.
- Bigbaldybloke
It used to terrify me too but once you have been through one, you get to be pretty nonchalant about the whole thing
before
after
- Slowtus
Get rid of the original solenoid! You don't need it. It just becomes an extra source of resistance in the starter supply. Colin Chapman would not approve of having extra junk in the circuit that could be done without! If you need to switch the ballast resistance circuit you can do so with a much smaller and lighter general purpose automotive relay instead of one designed to switch a couple of hundred amps.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Users browsing this forum: Coupe and 23 guests
