Gauge Lights
I just bought an Elan Plus 2 and this may be a bit of a silly question but are the gauge lights supposed to come on when the headlights are on?
- chickenstock10k
no......
on my early +2 you had the pull switch for the headlight up....the twist to turn them on....
then a flick switch on the dash that said panel.......this turned the dash lights on
Is it the panel switch? Second to the left on the top row?
http://classical-dash.co.uk/product-det ... an-2s-130/
- chickenstock10k
A +2S130 has a three position switch (labelled PANEL as you said) that controls the interior lights. On my car (which seems to be pretty original), the function is as follows:
The middle position is the normal setting. No idea why Lotus chose to have the gauge lights user switchable... there is no situation I can think of where this might be desirable.
[edit: Just as vxah said...]
- Up - Gauge and interior lights off
- Middle - Gauge lights on if side lights are on, interior lights off
- Down - Gauge lights on if side lights are on, interior lights on
JonB - Coveted Fifth Gear
JonB wrote:A +2S130 has a three position switch (labelled PANEL as you said) that controls the interior lights. On my car (which seems to be pretty original), the function is as follows:
? Parked on the road with the sidelamps on and dash lights off? Might give the battery an extra 5 minutes
- vxah
Well it looks like I have some troubleshooting to do since there appears to be be no sign of life with the gauge lights!
- chickenstock10k
