Smiths F465 Heater removal & Testing
Following on from yesterdays post...The wiring loom has been removed from the dash and I set about the easy task of removing the Smiths F465 Heater for refurbishment and testing........
https://youtu.be/LmJEvoIxx7Q
- djb222
Thanks for that. After all I did with my Plus 2's heater, I was curious whether or not the smaller Elan used the same heater- it doesn't. And it looks like the fan motor doesn't have as close a space to fit in either.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
Hi David,
Thanks for posting the link to your video. Videos like these are invaluable to people restoring their cars. Especially when years have passed between dismantling and putting back together.
One of the interesting things that I notice, is the orientation of the heater box side panels. There was some discussion, several years ago, as to whether the demister outlet tubes should be toward the front of the car or toward the rear (closer to dash panel) as yours are.
Your S4 is of the same vintage as mine, and my heater connections are as per your car.
Cheers, keep the videos coming,
Colin.
Colin.
djb222 wrote:Following on from yesterdays post...The wiring loom has been removed from the dash and I set about the easy task of removing the Smiths F465 Heater for refurbishment and testing........
'68 S4 DHC
- fatboyoz
Thanks for the comments.
If you watched one of my first videos, all of this work started with removing the engine to change the water pump (which is still to be done) and be back on the road last July. As often is the case one thing leads to another...........
I just love the simplicity of these cars and they are such a joy to work on. Ok some jobs are fiddly and a swear box is handy.....(door latches) Which I need to do again.
The pics and videos are fun to do and provide a reference and, if I ever sell useful for the new owner to see whats been done.
This story is far from over...
- djb222
My rule of thumb is that the swear box fills up twice as fast with reassembly than disassembly.
Great videos though - and some good piano playing as well
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
Interesting to see that the eye level vents come out of the heater box on the opposite side on my S3SE!
Here are some photos of when I refurb'd mine last summer.
Notice the face vent outlets are at the "dash side" of the heater box.
Paul Carew
Austin,Texas,USA
1967 Lotus Elan S3SE Right Hand Drive, FHC 36/7152 BOO 758F
Austin,Texas,USA
- pcarew
Paul
Apparently the dash outlets were moved to the back later to give more room for the wiring.
Some owners have moved them during repairs also.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
I found on this forum that it?s from an FX4 London Taxi. So I ordered one for that spec from eBay.uk. It came to the states quickly and was about $90 us.
Since then I found that the new Bucklands book confirms the taxi source.
Kyle
Kyle
'70 S4 Elan - Cosworth BDP & Spyder Chassis
'62 S2 Super Seven Cosworth
- disquek
ericbushby wrote:Apparently the dash outlets were moved to the back later to give more room for the wiring.
Eric,
I did not know that. This forum is truly a mine of information.
Thanks.
Paul.
Paul Carew
Austin,Texas,USA
Austin,Texas,USA
- pcarew
Paul,
I think it is mentioned in Brian Buckland's book. The main source of accurate information.
Eric
Edited for spelling
Eric
Edited for spelling
- ericbushby
Thanks Kyle,
Appreciate the info.
Colin.
Colin.
disquek wrote:I found on this forum that it?s from an FX4 London Taxi. So I ordered one for that spec from eBay.uk. It came to the states quickly and was about $90 us.
Kyle
'68 S4 DHC
- fatboyoz
I'm running about a week behind you - which is great for me!
Just got my Heater box out, although nowhere as lucky as you:
After a strip down & rebuild we're up & running for the first time under my ownership:
Now to put her all back together again...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
