S4 Sprint Tail light cluster lens gasket failure
Happy New Year fellow travellers,
Heres my latest bind:
My rear lamp clusters are original and in overall good condition. However, the lens seal has deteriorated, its hardened and in places has somehow adhered to the lens plastic. See Photos
I cannot believe that it will offer any resistance at all to water ingress. If you look at the photo of the lens, the reason the hardened seal is in place is that it is firmly stuck! I am sure that I can remove it cleanly with a little effort. So i'm going to need a replacement gasket. Can anyone advise me of a source?
REgards
Bob
REgards
Bob
bloodknock - Fourth Gear
Bob,
I think that the original gaskets were gray. This site has them but in black, if you don't mind the difference.
https://www.holden.co.uk/displayproduct ... K%20GASKET
Jay S.
Jay S.
Jay S.
1972 Federal Sprint, Colorado Orange/White
2005 Elise, sold
1988 Evante 140TC, sold
2005 Elise, sold
- Evante
Here as well. I bought these recently for my S4. Worked fine.
https://paulmattysportscars.co.uk/produ ... -s4sprint/
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
Thanks Gents.
The part i'm talking about is the seal between the lens and the light body, the grey part in the photo.
Since the car is all original, I would like to get the correct OEM seal if possible.
Bob
Bob
HI Bob,
They seem impossible to buy on their own (have looked for years). Pretty sure that a new gasket is provided when buying a new lens.
An expensive way to replace a gasket!!
Colin.
Colin.
bloodknock wrote:Thanks Gents.
Bob
'68 S4 DHC
- fatboyoz
Bob
on the same line the same grey was used for the license plate lights rubber gaskets, hard to find these days while black ones are still offered with new Hella spares
lotus-electrical-f38/source-license-plate-lights-sprints-t27227.html
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Steve at SJ has the gasket material too. They aren't supplied as the 'rectangles', but I shall join the two ends with a spot of glue at a convenient place.
The originals thinned down around the bolts in a couple of places, so it may need a bit of blade-work too. There's an original Lucas for sale on eBay https://ebay.us/SZGzb7 - LHS only, but the photo is useful.
Ned
Ned
+2S 1969 50/2283
NedK - Second Gear
Gentlemen,
My replacement lights came with foam rubber seals, and no thinned down areas. I suspect the thinned down bit is to allow water to escape. Does anyone know?
Richard Hawkins
Richard Hawkins
- RichardHawkins
Hi Richard,
The original grey seals have the cutouts, and presume these are to let any condensation out of the fitting. However, they are shaped to fit the lenses, and therefore there is a left and a right hand lens and seal.
The complete light fittings, when mounted on an S4 Elan, are upside down. The drains are then positioned at the top, and not on the bottom as per the design. I don’t know if this would let water into the lens, but many years ago, I cut them up, and glued them back together so that the cutouts are at the bottom. Anal? Perhaps.
Colin.
P.S. Or perhaps I had the wrong part number seals.!!!!
Colin.
RichardHawkins wrote:Gentlemen,
Richard Hawkins
'68 S4 DHC
- fatboyoz
Thanks for the advice.
Richard Hawkins
Richard Hawkins
- RichardHawkins
