Instrument lights
Am I correct to guess that they're not supposed to be this dim? This is with 12.3-12.4V at the battery and 11.6V at the lamp. I can not discern any light from the lamp making it to visibility in the face of the instrument.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
Earth seems good, and I even scrubbed the contact areas for the lamp holder and the corresponding surface of the instrument. Since I haven't dealt with this type of lamp before I'm not sure how bright they should be.
2012 BMW R1200GS
2012 BMW R1200GS
The earths are rings fitted to the studs that hold the instruments in place. On the studs there are little knurled nuts that can need tightening with your fingers. The earths are a daisy chain.
- alan.barker
Fairly certain that it's an E10 base but I can't make out any of the microscopic markings on it. Looks like what flashlights used in the old days.
2012 BMW R1200GS
2012 BMW R1200GS
It?s worth noting that these bulbs are rated to cope with the voltage with the engine running which is likely to be a couple of volts higher and the bulbs would be brighter. Having said that I would invest in some led bulbs which would potentially provide a stronger light. I have these in my speedo and tachometer and have been a great improvement
I would agree with Jon B that connecting the bulbs directly to the battery would prove if you have a bad connection.
Ed
Ed
EPA - Second Gear
A multimeter, Ohms, Volts, Amps is as important a tool as a socket set for classic cars.
So if you haven't got one.. Buy a multimeter as soon as practical. they are really inexpensive nowadays.
You would have a definitive answer to your dim bulb problem in just a few minutes with a volt meter.
See my post up top. The question isn't whether or not the voltage and earth are good- they've already been checked; less than 1 volt drop from battery to lamp socket and the dashboard earths are connected straight to the battery via jumper cable. The question is whether the lamp should be so dim, because I have no prior experience with these. I think the answer is 'no' at this point, so I'm looking at some LEDs so I won't have to go in after them again for a while.
2012 BMW R1200GS
2012 BMW R1200GS
It does look dim to me but very hard to tell in photos. Does the bulb have a wattage rating? Or can you measure it's resistance?
That should confirm if it is the right bulb or not. Maybe a mute point thou if going to go to LEDs...
- mbell
