+2 ignition lock bracket
Posted: Sat Sep 08, 2018 7:45 pm
Investigation a smoking indicator switch has lead to full strip of the steering column to address a few minor things.
One of those things was movement/turning of the ignition lock that was messing up I the trim positioning.
On stripping it down the bracket seems to have a provision for a clamp for the lock that isn't there (see picture).
Not sure if it is messing it were never fitted from the factory?
My options seem to be fit a bracket there or drill out the bolts and refit the lock to the column.
Any other thoughts.
Any other thoughts.
