Install Petronix distributor
PostPost by: collins_dan » Sat May 12, 2018 7:58 pm
My shop manual is in a safe place. I just am not sure right now where that is. Can someone scan the pages for removing the distributor. Head doesn?t need to come off, does it. The space is so tight it?s hard to tell. Thanks, Dan
collins_dan
PostPost by: richardcox_lotus » Sat May 12, 2018 8:19 pm
Dan, the head (and carbs) can stay in place. Just don?t turn the engine until after you re-install it.
'72 Sprint
PostPost by: rgh0 » Sat May 12, 2018 11:56 pm
Just remove the dizzy cap and rotor and release the clamping bolt and you should be able to pull it up and out with it just clearing the underneath of the carbs.
PostPost by: collins_dan » Sun May 13, 2018 4:08 pm
Ok, thanks. Dan
collins_dan
