Page 2 of 2
Re: Zetec temp sender woes
Tue May 08, 2018 5:22 pm
by pauljones
- Water temp sender
- Water temp sender
- Block rhs
Ok so i took a photo of mine.
On rhs under no1 cyl and behind the alt i have an oil take off. Behind that by about 12inchs, thats what i tell her anyway, is a blanked plug.its.about 3 inchs to the rear of it.
Also i include my temp sender and its in same position as yours just on a take off. I assume for coolant to the heater matrix.
Tue May 08, 2018 5:57 pm
by pauljones
Some more pics.
Looking from rear forward, i have no more on lhs but there is a space rear center of coolant rail, should you have space i guess.
There is Also a fitment rhs off head. A knock senser i assume.
Having had a look around it as its on the floor, the only other senser i see is for the flywheel pick up point.
Im guessing you may have incorrectly wired up bit n bobs and that ill admit is a step into the dark arts for my brain power. But if you need anymore photos as engines out let me know.
Tue May 08, 2018 6:14 pm
by TAS
Spyder fan wrote:The temperature sender is tight against the bulkhead on the head on the LH side.
Off to look now...
Tue May 08, 2018 6:23 pm
by TAS
TAS wrote:Spyder fan wrote:The temperature sender is tight against the bulkhead on the head on the LH side.
Off to look now...
We have a winner, no idea if there?s enough room to get it out to change it!
Tue May 08, 2018 7:05 pm
by pauljones
Tas
Do you have one where mine is blank?
Tue May 08, 2018 7:15 pm
by TAS
Thanks Paul,
I think mine must be screwed into the back of the water rail where you have a blanking plug showing. My radiator hose has a joiner with a plug in it that I am going to use for now to test another sender now I have the correct wire.
I?ll worry about whether I change the one at the back of the block once I have solved it. I seem to have an abundance of sensors! The one on the right hand side is disconnected currently and nothing has stopped working.
Tue May 08, 2018 7:33 pm
by pauljones
Tas
Not me to thank. Alan again wins this round of top lotus knowledge. I just took pics as a guide. Glad to assist tho.
Please tell me about your header tank and any take offs for heater matrix.
Is your header tank just an overflow or does it feed into coolant hose?
I think i want one just as an over flow not feeding into the system, i may need to change my plans.
Also i have a take off block of ally that goes where your other coolant rail sender is, this houses my sender and has 2 feeds/returns that im assuming was for the heater matrix. In which case i only want the sender in, this opens up the routing for heater,
Any pics of plumbing would be helpfull as this was the main reason for my engine out.
Tue May 08, 2018 7:38 pm
by Bud English
Taz- Glad you found it with help from Spyder Fan. He'd be the go to guy for Spyder conversion info.
pauljones wrote:There is Also a fitment rhs off head. A knock senser i assume.
Not pertinent to the subject at hand, but In case someone else is sorting out zetec sensors, that's the cam position sensor. It's not used on most zetec conversions and a 1" freeze (Welsh) plug ( Dorman 555-018 US) is a close fit to blank it off. Use sealant and stake it as it's not an exactly a press fit.
Tue May 08, 2018 7:45 pm
by TAS
pauljones wrote:Tas
My header tank has an outlet at the bottom that feeds into the system. I?ll take some pics tomorrow for you. There?s a lower pipe that it feeds into. My heater is teed off the rail where the ecu temp sender is in my first pic, I?m not sure where it feeds back in. I?d like to put a valve on it to cut the heat in this weather but there doesn?t appear to be enough room in the engine bay side, I?ll look at the interior instead at some point.
Fri May 11, 2018 3:13 pm
by TAS
The wire attached to the sender on the back of the head is at 12volts constantly so I guess not connected to the voltage regulator. I?ve connected to a new sender in the top hose and the gauge doesn?t move
I guess I need to take the dash off check the wiring next. My dash is held on with Allen headed bolts that have nuts behind, does the dash top come off so I can reach the top ones?
Fri May 11, 2018 3:32 pm
by Spyder fan
Is the new sender grounded? You say ? in the top hose?
This may be worth a read
http://www.abs-zero.com/project-pages/1 ... tabiliser/It looks like you have established that the gauge is wired incorrectly ( no voltage regulator) and that there is no overheating issue, so treat the gauge as a pretty bit of bling safe in the knowledge that the fan will cut in from its own sensor when needed. It?s nice to have these things working properly but they are just ?idiot gauges? after all.
Fri May 11, 2018 3:59 pm
by TAS
Spyder fan wrote:Is the new sender grounded? You say ? in the top hose?
Doh no it?s not grounded! It?s in a joiner between two silicon hoses. I?ll try grounding it and see if it registers!
It still needs a regulator so I need to work out how to get the dash out which doesnt have standard fittings, I?m sure there shouldn?t be normal nuts loose on the back that need a spanner attached. It looks like the top will come off first to allow a spanner access.
