Zetec temp sender woes
Following on from my intro post I?m trying to solve my erratic temp gauge. I?m pretty sure it?s not running hot but the gauge runs between 120-140. It took me a while to fine where the sender was, it?s on the right side of the block below the throttle bodies, not on the water rail. When I put a meter on the sender it reads 0 or 12volts alternatively which I guess means I have no voltage stabilizer. The sender also looks nothing like a smiths one, it has a round terminal and is 22mm, I think it may be a ford one.
I?m going to change the sensor first for a smiths one once I can get a deep enough socket to get a purchase on it, I?m not planning on taking the throttle bodies off!
Should I see 10 volts on a meter?
- TAS
No.
Swinging between zero volts and battery voltage is how the voltage stabiliser works.
Zetec water rails might look nice but completely cock up what was a very well considered cooling system, at the very least you need to drill a 3/16" circulation hole in the thermostat which should have remained at the back of the engine where it belongs.
- Chancer
Chancer wrote:No.
Great, the new sender might be enough. Already got the hole in my thermostat
- TAS
Tas.
Can you post some pics of where your at?
I ask because i have my zetec out, i can have a look at mine for you. I have omex temp sender which i believe is different to my emerald one. And i also have the standard one on twincam too. So 3 possible different ones.
My silvertop zetec has a water rail and the sender was fitted to it and not under the bodies on rhs. Are you sure thats not oil?
My temp gauge reads high (as does fuel) because it was rewired 12v with no voltage stabiliser. I can live with it for now. Was thinking of using 12v gauges if and when i re do the dash.
- pauljones
Taz- I'm not sure the ford sensor is compatible with the smiths gauge. I also don't think you'll find a smiths sensor that will work in the CHT location.
Some of the zetec motors, like yours, have a cylinder head temp sensor and no coolant temp sensor. It's located on the intake side of the head. It actually measures the temp of the head and doesn't even contact coolant. When you remove it you don't even have to plug the hole. My crate motor came that way. I put two coolant sensors in my water rail, a smiths sender for the gauge and a GM sensor for the ECU. Over kill, maybe??
http://www.webcon.co.uk/Downloads/K4001 ... lack%20Top)%20Eng%20Temp%20Sensor.pdf
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
On my home built water rail, I placed a Smiths sensor directly behind the thermostat. It picks up the coolant temperature where is should be the warmest. Not advocating building your own rail, but like the TC's, that is where the sensor is located.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
That must be an added coolant sensor in the block, not the head temp sensor, obviously. The forward sensor is the oil pressure sender. On my block, I have a threaded plug in the position of your coolant sensor, that I assumed was an oil gallery plug. Shouldn't assume, but it will be interesting what you find when you pull the sensor. Oil or coolant??
In this old pic of my motor mount fabrication, you can see the plug in the position of your sensor. The oil pressure sender in behind the pigtails (one of the pigtails is from the cylinder head temp sender, the other from the knock detection sender).
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Bud English wrote:That must be an added coolant sensor in the block, not the head temp sensor, obviously. The forward sensor is the oil pressure sender. On my block I have a threaded plug, that I assumed was an oil gallery plug. Shouldn't assume, but it will be interesting what you find when you pull the sensor. Oil or coolant??
I?ll find out tomorrow, I thought I read somewhere that the fan switch lived there on some cars.
- TAS
The mystery deepens. I unplugged what I thought was the temp sender and my gauge still works..
I've no idea how it's getting a signal unless it's piggy backed off the ECU temp sender which is a modern one. I've just take it to my local Caterham specialist who couldn't see where its plumbed in either.
I'm going to rewire the gauge to a smiths sender in the top hose.
- TAS
After another look at your water rail photo (enlarged) it looks like the water rail has two temp sensors in it. One is coming straight out the front under the filler cap and the other is threaded into the boss about four inches back from the cap. I can't tell from the photo if both have two wires connected, but the smiths gauge should have just one.
What I thought was the sender that you were talking about in the exhaust side photo looks like a connection for a mechanical oil pressure gauge, the other is a sender for an electric oil pressure gauge or an oil pressure switch.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Bud English wrote:After another look at your water rail photo (enlarged) it looks like the water rail has two temp sensors in it. One is coming straight out the front under the filler cap and the other is threaded into the boss about four inches back from the cap. I can't tell from the photo if both have two wires connected, but the smiths gauge should have just one.
The one under the filler cap is a fan switch, and the other one is for the ECU, if I pull it off the engine changes maps and the mechanic confirmed it was the ECU sensor.
The wiring to it is wrapped so I cant see how many wires connect to the plug, I think it may be connected to the gauge as well.
- TAS
Is your gauge feed an input from an ecu output? Can you confirm what voltage is sitting at the gauge, maybe you are getting a constant 12v feed.
Im just about to look at my zetec block, ill let you know what i have.
- pauljones
The temperature sender is tight against the bulkhead on the head on the LH side.
Kindest regards
Alan Thomas
Alan Thomas
