Quick way to check the voltage stabiliser
I suppose it matters what range you have it on....10-20V and it will swing , 0-100V less so ?
..or is it the other way round?
Maybe the easiest way is to fit a new electronic Voltage Stabiliser (very cheap).
I suppose the old one is screwed to the back of the Speedo which means it is earthed
and vertical of course. "B" battery supply and "I" to Gauges
- alan.barker
Jon,
85?c sounds good for me but a useful tool is a IR Thermometer
- alan.barker
So... last night I thought I'd pull the underdash trim and take a look at the regulator, as a new electronic part had arrived in the post. I found that it is not attached to the back of the speedo or rev counter, but instead it is screwed onto the back of the dashboard, on the right hand side but not accessible. It has its own dedicated ground wire, too. Unfortunately I could not get to it, or pull the wires off it (I was going to wire the electronic part in temporarily to see if it made any difference), there is not enough clearance back there.
What I did notice was that the dashboard loom looks suspiciously clean for a 45 year old car.. so it may have been replaced when the car was restored in the early '90s. Maybe!
I also checked the fuel warning light. I was unsurprised to discover a missing bulb. As I don't have a spare I left it, but I'll be revisiting it very soon.
JonB - Coveted Fifth Gear
