Positive earth S3
My elan S3 is positive earth. Should I change it to negative earth? Si there some benefit?
- Dieschelan
I changed my positive earth to negative , it's quite easy.
The benefits are , 1st you can install an alternator which are all negative earth , you can fit modern radio / audio equipment if you choose.
But you have to re-wire the tacho , internally other than that i think everything else works.
- Concrete-crusher
And your window control switches will work backwards until you reverse the wiring on the back of the switches.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
