Disassemble Early Window Switch
During my minor re-wiring project I've found a issue with my passenger side window switch. It was a bit dodgy from when I got it, and it's appeared to have gotten worse. It will work in one direction, but generally not the other. I think it just needs a good clean.
Is it possible to disassemble the switch? I removed it and have had a look, but I don't want to force anything as they appear to be a bit hard to replace! I've read of people spraying contact cleaner into the switch and operating it a bit - I've also read that there is a chance this could damage the plastic in the switch...
This is the one I'm referring to
Elan +2 #0245
Exige S2 Supercharged
Elan +2 #0245
- Chrispy
Never had one apart but from the looks of it a little drilling of the top of the rivets and it should come apart ..
Be careful of little springs and things flying everywhere
- alan.barker
Is this a problem w/ a toggle switch or rocker switch?
I've had both my rocker switches apart on my S3 SS, cleaned and reassemble w/ very favorable results.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
I suppose you'd call them a rocker switch, but it's not the flat plastic ones. Here's some more photos I found online (off a jag, but appears to be identical). I'm away for work at the moment so I can't take a photo of mine.
I couldn't see much in the way of rivets to drill out to get into them.
I've found a few references to pulling apart the plastic rocker switches, but not these chrome ones.
Elan +2 #0245
Elan +2 #0245
- Chrispy
Rivets top and bottom and then the plastic should come away from the front metal plate..
I disassembled my Sprint late model rocker switches, because my windows were moving up and down so slowly. I cleaned the contacts with steel wool and then put a drop or two of Deoxit on it. Just doing that made the switches, and the windows, operate a lot faster.
Gary
'71 Sprint FHC
Miami, Florida
Gary
'71 Sprint FHC
Miami, Florida
archigator - Fourth Gear
My SS rocker switches were same as in Gary's photo. I cleaned my contacts w/ a pencil erasure; much faster speed for the windows.
'67 Elan S3 SS DHC
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Can't see from the photos but what I do generally is drill in gently from the plastic side and just remove the peened over head , this will leave a tube in the body that can be persuaded out with the metal cover , after cleaning and reassembling a drop of superglue on the tube is usually enough to keep it in place..
That is if you cannot source a couple of hollow rivets.
So just after I got my drill out and all ready to get stuck in I got a bit of isopropyl alcohol anencephaly sprayed liberally into the switch and gave it a good toggle and she?s come good! So no pictures of the inside unfortunately, but I have a working window again
Elan +2 #0245
Elan +2 #0245
- Chrispy
A bit late it seems as you have yours working again, but I found these on a well known auction site. I have no connecting with them but might help someone... https://rover.ebay.com/rover/0/0/0?mpre ... 2358714618
- Nickm
