Spare good distributor or coil for sale?
Posted: Tue Oct 17, 2017 4:25 pm
I am attempting to trace a fault that caused Toad to spend another trip on the breakdown truck.
lotus-twincam-f39/misfire-then-will-not-pull-hill-t40445.html
I've stripped apart the fuel pump and carb. filters and all seems fine.
It is fitted with an accuspark electronic distributor.
Anyone have a good spare distributor or coil I could have to eliminate the next suspects.
The coil is also wired somewhat strangely. What is the blue / yellow wire on the negative.
The power comes from the thin white wire that is connected to the tacho! That has to be wrong surely?
Remember the Spyder connection. Anything is possible.
According to the workshop manual the coil is supplied from the solenoid. I take it this was changed.
Where should it come from on an S130?
