Plus 2 Electric Window
Ok People
Emergency advice needed - I'm at good wood revival next week and the drivers window is stuck in the down position.
How do I remove the window and the motor to test it?
Pictures so you can see what I see!!
You can see that I have removed two of the bolts but the motor does not want to move
Help needed - even if it is a short cut to get the window up.
G
G
To get something you've never had, you need to do something you've never done!
- GHill
So I managed to move it (was not applying sufficient elbow grease) and was able to get the wires off of the motor.
Quick check with a voltmeter shows that I am getting sufficient voltage to it (see below photos)
So therefore i assume that the motor has died?
So two questions
1. Where do I get a new motor - is it the usual suspects (Matt, Miller etc)
2. Could it be something else i.e. Over extension of the arm?
3. As I need to use the car next weekend is there a way I can get the window in the fully up position?
G
So two questions
G
- GHill
Just because you are getting " the right " voltage to it doesn't help....you need the current , a high resistance connection will still show a " good " voltage but will reduce the current so low that it will not work..
P.S are you measuring between the two wires OR one of the wires to earth ?
EDIT just re-read your post and it looks like you're measuring each wire to earth..
It's the earth (is t it always)
Fitted a wire from the earth on the motor to the earth lead in the engine bay and then it worked so just need a new earth lead and the reinstall.
Phew
G
John - yes was measuring each wire to a fresh earth
Phew
G
- GHill
It's just a motor that keeps rotating till you take your finger off the button , looks like you may have a problem with the fan shaped cog that lifts the arm...
