Unidentified f****ing objects
Hello folks
whilst rooting through all my bits, which were once a car, ive found the washers shown in the photo:
The dark washer in the photo has a very rough textured surface, like coarse emery. Its outer diameter is 1.0 inch, inner 1/2 inch.
The smaller washers are fiberous.
I imagine that the rough ones are used to perform some kind of locking function, but i dont know where.
Bob
Bob
bloodknock - Fourth Gear
KevJ+2 wrote:Door locks
Times two.
Friction Washer, Private Lock Mounting and Washer, Private Lock Mounting , listed under item 47, plate BK, in the +2 parts manual.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Elan Fan is correct on the emery cloth items.
James
James
Bob,
The emery type washers are fitted to the door lock barrel inside the door under the nut on my '68 S4. Can't help with the fibrous washers.
Colin.
A
Colin.
A
bloodknock wrote:Hello folks
Bob
'68 S4 DHC
- fatboyoz
On my +2 some emery washers were fitted on the bolts fixing the rear chassi cross brace. Part no 036 B 0685 shown in the parts book?
- elanman999
Thankyou gentlemen
heres the rub,its an Elan Sprint. I should learn from this, always specify the car model youre talking about!
I didnt think of the door locks Colin, thanks.
regards
Bob
regards
Bob
Just another data-point; the only place I've found them in my '70 federal Plus 2 is between the ignition switch and dashboard. I haven't been in the aforementioned are of the doors though.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
If as has been advised, the friction washers are used to anchor the choke, vac headlamp switch, heater pull, etc, where exactly are they fitted. I've put one at the back of the choke pull...see photo...is this correct?
