Oil Pressure tube and Mouse holes.
I got all my steering column bits/seals from Rimmer brothers. https://www.rimmerbros.co.uk/Category-- ... rts--m-602
That said the column seal was nothing more than some 2mm rubber sheet with holes in the appropriate places (take five mins to make one up)
Grizzly - Coveted Fifth Gear
I bought a seal from Sue Miller, (along with a Goodridge braided pipe).
As Grizzy stated above its nothing special, and the holes will likely not line up anyway, so I'll probably end up making one. I've a good bit of nitrile sheet left over from attempting to make a cam box gasket.
I doubt it will be possibly as the red/black leads will be too short. The HT's should be OK as they are the posh silicone Magnecor things (?80 !!).
As I said - that's how it came.
pharriso wrote:p.s. I would rotate the distributor & cap 90 degrees so as not to put a strain on the leads...
- vincereynard
The Triumph column seal was a poor fit so I made one by bonding a suitable grommet into a 2mm strip of nitrile (super glue works well.) The nitrile allows the grommet to line up nicely with the shaft.
I've also fitted the braided oil pressure hose. That was a bit of a problem as it is much stiffer than the nylon pipe and the screen vent ducting gets in the way.
- vincereynard
For some reason the restorers fitted new, expensive insulation everywhere EXCEPT the front footwells??
And it is still possible to see just a slither of light coming from the engine bay, so the posh seal requires a bit of a tweek!
N.B. When replacing the column don't slide the splines too far into the rack U/J or the taper on the back of the steering wheel can touch the column and the horn blows continuously.
It took a lot of wiring checking to discover that!
At first it looked like whenever the indicator switch was touched the horn sounded.
- vincereynard
