Car won't start no spark
alan.barker wrote:When i fit spades or bullets i crimp + solder (belt + braces)
I strip about twice the length of the crimp 'tunnel' spin the strands together then fold the bare wire in half and push that into the crimp tunnel, then crimp the tunnel as close to the front as possible and a second time next to that first one, then I crimp the insulation at the back end of the connector so that that insulation holds the insulated wire securely and prevents fatigue failure of the inner wires.
For me that's what i call the Pigtail inside Dissy and it remains static i think.
- alan.barker
alan.barker wrote:For me that's what i call the Pigtail inside Dissy and it remains static i think.
You are partly right & I was partly wrong
It does move, but not at the rate I mentioned, it moves with the baseplate as it advances and retards, so not quite 2x6500 times per minute, but to & fro as you accelerate & decelerate.
<later>
This is wrong too see below.
Yes, base plate fixed. Advance and retard is on the dissy shaft with the springs and bob weights.
The Pigtail doesn't move.
- alan.barker
Oops you are right.
The 4-corner cam moves relative to the shaft under the effect of the weights moving out. So the points remain fixed relative to the Distie case.
Oh well it is quite a while since I last had my distie off the engine.
Hi Bill,
it's o.k. next time it will be me who makes a mistake
- alan.barker
I have tried swapping pints
Seldom a good idea. Ale and motor oil just don't taste the same. And yer engine likely feels the same way.
- denicholls2
denicholls2 wrote:I have tried swapping pints
Not a bad idea if you want to talk about BHP at the Flywheel while drinking HSB
- alan.barker
