Low alternator charge
• Page 3 of 3 • 1, 2, 3
andyhay wrote:It was the white wire in this photo (not my car - photo from google search)
That's the wire from the starter switch to operate the solenoid. That solenoid does not have the ballast coil extra contact.
Maybe you also slid the big brown wire to & fro on its contact and cleaned the connection without realising it. As prezoom said, since that is the main feed to & from the battery, dirty contacts there could make strange effects.
Yes
If you had a high resistance join from the alternator brown wire to the main battery cable you could get the symptoms you had. You may want to remove the connections on the top of the solenoid and clean and reinstall them ensuring they are all tight.
rgh0 wrote:Yes
CAREFULLY..!!
Disconnect the battery first because that big fat black leads goes straight to the battery terminal.
Be sure to check the connection at the alternator as well.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
I know this may sound a little odd but have a look what size Bulb you have in your Ignition tell tail light. I was having all sorts of problems with my Alt doing strange things and it turned out it didn't like the 2.2w bulb, fitted a 5w and it works as intended now (14v at 1000rpm idle and 14.4v at anything over 1200 rpm)
Grizzly - Coveted Fifth Gear
