S3 Electrical Diagram
This may be a silly question, but . . . .
in looking at the S3 diagram I have most of the wires go to a long, thin, vertical box with cross hatching and proceed out the other side. Is this box indicating the firewall?
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
fattogatto - Third Gear
Most logical.
Thank you.
Thank you.
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
I should've also said that the connection (all the bullet connectors) actually happens just inside the body side of the firewall. So engine bay loom wires all go through a grommet/firewall hole and into the body where they then connect to the body/dash loom.
36/6612
1967 S3 Coupe (left the factory in 66)
original rego PPC 8E
original owner B.M. Wetherill ..are you out there?
dgym - Third Gear
Thanks. Installing a fuse block with relays and will be able to rid myself of many of the bullet connectors.
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
fattogatto wrote:Thanks. Installing a fuse block with relays and will be able to rid myself of many of the bullet connectors.
Have a look here:http://www.lotuselan.net/forums/lotus-elan-f19/anti-theft-swich-t38941.html
Cheers Urs
ElanDNA - Second Gear
