Circuits needing relays
I am completely re-wiring a 1967 UK version S3 Elan. I have the option of using up to 11 relays with my current (no pun intended) equipment. Choices are:
Headlights - main
Headlights - dipped
Left window up
Left window down
Right window up
Right window down
Horn
Electric radiator fan
Heater fan
Any other suggestions?
Headlights - main
Headlights - dipped
Left window up
Left window down
Right window up
Right window down
Horn
Heater fan
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
fattogatto - Third Gear
One for the accessories and one for the ignition to relieve the stress on the ignition switch ?
Wiper motor draws significant current, particularly with a dry screen. Two speed motor / self parking will need some thought though to use relays.
The solenoid used for pre engaged / geared starters can draw significant current if you have one fitted.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
john.p.clegg wrote:One for the accessories and one for the ignition to relieve the stress on the ignition switch ?
I've been starting to think about custom loom for my plus 2. I agree with John on this, I was planning a couple of big relays for switching the ignition circuits on.
Basically any device that pulls a significant current would go through a relay.
My first step with be to spread sheet every electrical device in the car to map out wire colors, location, current, power source. From that I can identify relay and fuse requirements.
- mbell
Thanks for the replies.
The draw from an ignition circuit, especially an electronic (e.g. Pertonix) should not be much. Although, with an extra relay available it would not be a bad idea.
Same for a gear-reduction starter. The wire from the start switch merely triggers the solenoid, acting as a type of relay itself. At least that's always been my understanding. Someone please correct me if I am wrong.
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
A rather simplistic approach but if it has a thick wire, consider a relay!
- mikealdren
A relay for ignition circuit is good idea to separate the pertronix power line from the coil supply for the tach. I also run elec fuel pump, rev limiter, alternator line of that circuit via the relay. None of it is that high power but relay is good for extra reasons:
- relay is triggered via a fuel cut of switch so crash will kill fuel supply and engine
- removal of the relay gives good security measure
- the relay will trigger with a voltage lower than 12v, so even if isn't switch isn't great you get more reliable operation
- relay is less likely to get a bad connection and much easier to fix/replace
I am not sure what the current pull for the solenoid is but I'd expect it to be quite noticeable, amp or so, as quite a heavy device. So worth considering a relay but given amount of time it is active it might just be a little bit of over kill but a lot of the above probably applies...
- mbell
Gear reduction starter research shows use of a 12 - 14 gauge wire recommended for the starter switch with typical amp draw maxing out around 15 (which is max for a 14 gauge wire at normal temps), depending on length of wire. Not a bad idea to use a relay for the starter and 12 gauge wire from the relay..
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
relays are to protect cheap switches[in new cars] or enable automation
they add failure points and will become impossible to decipher years from now
How many switches have you replaced?
I have replaced my microswitches, kill switch....that's it
replaced horn and low beam relays
IF you have 2 fuse wiring, it could use more fuses, the last +2 had 4 which I think is fine.
Increasing wire size and ground size is really all that is needed.
adding complexity is asking for trouble.
- gus
fattogatto wrote:I am completely re-wiring a 1967 UK version S3 Elan. I have the option of using up to 11 relays with my current (no pun intended) equipment. Choices are:
Headlights - main
Headlights - dipped
Left window up
Left window down
Right window up
Right window down
Horn
Heater fan
Charlie,
If you Elan is a Coupe, another circuit that would benefit from a relay would be the rear window defogger.
Dan
fattogatto wrote:Thanks for the replies.
The solenoid on my high-torque starter pulls 35A. According to the Bosch Automotive Handbook, this type of starter/solenoid will pull over 30A so a relay seems a good idea.
'67 S3 SE FHC
'67 S3 SE FHC
Galwaylotus wrote:fattogatto wrote:The solenoid on my high-torque starter pulls 35A. According to the Bosch Automotive Handbook, this type of starter/solenoid will pull over 30A so a relay seems a good idea.
Aye, but you need a high-current contacts relay for that. Which is exactly what the old starter solenoid is. It's only a relay in any case.
I know that but I didn't have one and I did have a 40A continuous relay so I've used that instead.
'67 S3 SE FHC
'67 S3 SE FHC
