Radio
Hi Dave
I think it will - it's all a question of depth - a search will get you the definitive answer, but it looks OK.
The dash hole is larger than DIN so you'll need a faceplate adapter that you might already have or could make up?
Generally to remove, pull off the volume and tuning knobs to get access to the large flange nuts. The Radio is usually held in with through-hole brackets.
Vernon
Vernon
vernon.taylor - Fourth Gear
I'd love to know how you get on with this Dave, as I would love to have some tunes for longer drives.
Currently I still have the original turnolock, but the reception is rubbish so I don't bother putting the aerial up or turning it on.
Kind regards
Rich
Kind regards
Rich
- Rich135
Hi Dave. I am having difficulty with what is meant by the dimensional diagram. If the overall depth of the unit is 177 mm it definitely will not fit in a Plus 2 as it will foul the heater box. If the 101 mm dimension is the unit depth you are good to go. I don't have the stock clearance to hand, but this thread discusses the issue...
lotus-electrical-f38/car-radio-t21183-15.html
There are several threads that show how the heater box can be modified to provide more depth, but even with the modifications, the clearance is tight. Note the DIN dimension standard does not include depth, although I found modern units typically require 7" or more.
One additional issue I had when looking for a modern head unit was that the manufacturers don't necessarily include clearance for the wires at the back of the unit. This can be problematic if your install includes RCA connectors or similar.
HTH
Stu
HTH
Stu
Stu
1969 Plus 2 Federal LHD
The really great thing about RetroSound is that the front panel can be removed from the body and connected via a cable, so you can remotely mount the body in a roomier location.
I'll be putting one in my Plus 2.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
Hi Dave,
There are plenty of threads on this forum relating to your question.
I have this in my plus 2:
https://www.caraudiocentre.co.uk/produc ... 25970.htm#
Fits a treat, no mods to the dash or heater. 40W per channel and has an SD card for all your music.
At the moment it is ?35 at the above car audio centre.
They have others if you fancy them.
Kind regards
Jeff
Kind regards
Jeff
jeff jackson - Fourth Gear
Hi Dave,
OOPS!
Sorry just checked mine is discontinued,but there are plenty of others....
https://www.caraudiocentre.co.uk/produc ... -33248.htm
Pioneer, Sony etc..
https://www.caraudiocentre.co.uk/catego ... c-2809.htm
Jeff
OOPS!
Pioneer, Sony etc..
Jeff
If you have the original radio get it adapted to power switch to FM and add mp3 player socket (there are several reputable guys who do this including ChromeLondon and Agenta Audio of Ilkley) for your iPhone or whatever player, I have socket in glove box but also one that sits under the central tunnel trim, works great. My original radio works but sound is awful and it was when I bought car in 1980!
- Eric the Viking
Hi Dave. I've just fitted the RetroSound in the dash, which I went for as it's fractionally shallower than the CCS. No DAB however, but all the other bells and whistles, disguised in something that looks a bit more period IMO.
It *just* fits, with the back pressing hard on the heater box and wiring! The main body is fractionally proud still, but the faceplace (from the original dead Philips that came with my +2) bends around it slightly so it seems to fit reasonably well. I've wired mine up with an internal amplified aerial hidden under the dash which seems to pick up well - one of the advantages of a GRP body!
Very pleased with it so far...
...But completely pointless as I can't hear the thing over the engine noise!
- Telster
I've got a RetroSound in a Sunbeam Alpine - I can hear that up to about 40mph!!
Don't forget that you can get an "extension" cable for the RetroSound (about 2m long i think), allowing you to mount the "body" away from the face, which should prevent almost all issues with obstruction to the rear:
https://www.youtube.com/watch?v=CAaGet9P5RM
sdenny - First Gear
Yep I'm definitely going to be using the extension cable, although I haven't yet decided where to mount the body. I've had the radio for about a week now and the body is smaller and lighter than I expected it to be, and having it to hand is definitely giving me ideas for the install. I've got a bit of time before I'll be ready to install it, so by then I'm sure I'll have a good plan. May wind up adding an amp due to the aforementioned volume issues. Plenty of space in the Plus two for hiding amps and such!
2012 BMW R1200GS
2012 BMW R1200GS
