s4 main beam dip beam switch
Hi Folks
Anyone tried one of these as a replacement main/dip beam switch?
http://www.rimmerbros.co.uk/Item--i-152616
Mine has stopped working again- When it stops working I take it out and clean it with contact cleaner and it works for a few weeks and stops until it is cleaned again?- think I could remove the switch blind folded
George
George
- Type28
William2 wrote:Why not get a cheaper one off Ebay, there's usually quite a few on there.
There's always plenty of Triumph indicator & overdrive switches on ebay, but I've not found the dip/main switches, could you post a link please.
The Rimmer bros unit in the link fromType28 is, or at least looks, identical to the original in my +2. It has the flash facility, which was not much use with the vacuum failsafe system, as it was too slow, but since I've converted to electric, it's actually quite handy. My S4 Elan has a more basic type dip switch from the Spitfire MK4 & early 1500 which doesn't have the flash facility & seems to now be unobtainable, but I can see no reason why the type with flash wouldn't fit & work.
George, if your switch works for a while after a clean, then plays up again, it would suggest there is too much electrical load on it, do you have the correct relays in the system? If so, the dip switch should only be supplying power to the relay coils & this should not be enough to cause any build up of crud on the contacts.
Regards, Tim
- Orsom Weels
