Engine Cooling Fan Wiring
I know this should be straight forward but here goes.
My late +2 S130 arrived with just remnants of the original wiring loom, having been cut up by the PO.
With a new loom bought from Chris Neil quite a few years ago, I am trying to sort out a few of the discrepancies.
The Lotus wiring diagram shows three wires to the cooling fan motor; yellow/green, black/green and a black earth.
The old loom has the remains of these three wires at the correct location. A stud on the fan motor has an extra nut where possibly the earth wire ring connector was attached.
However, the new loom and its diagram does not have an earth and I cannot understand why it should have one.
Can anyone please confirm their wiring arrangement for the fan motor with or without the earth.
Gary
Gary
- Attachments
- Wiring Diag Extract.pdf
- Lotus wiring diagram extract showing fan
- (285.75 KiB) Downloaded 420 times
Gary
1972 Elan +2 S130/5
2001 Elise S2
1972 Elan +2 S130/5
2001 Elise S2
- Gazzerb
Here is a drawing of the wiring for a +2 s 130
Shows one feed and an earth
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
Hi Gary, I recently acquired a Plus2S 130 radiator cooling fan for my Sprint & noticed the extra earthing connection on the motor case.
"Can anyone please confirm their wiring arrangement for the fan motor with or without the earth."
Don't worry about that extra earth to the motor case, it is not required. Not sure why it was added to the Plus2S 130 wiring! The motor works fine with just 2 connections.
p.s. The original Lotus wiring puts full motor current through the Otter switch thereby shortening it's life. If you take a look at my thread here http://www.lotuselan.net/forums/lotus-electrical-f38/sprint-electric-cooling-fan-wiring-t38473.html I have provided a wiring diagram adding a relay to switch power to the motor.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Hi Gary,
Not 100% on this but on my early S130 the one with the same wiring as an S , I think that earth fixing could be for the bonnet. (Hood) lamp, as the wiring for it is running along the steel tube at the front of the bonnet and terminates by the fan.
Phil
Phil
- p.faurie
p.faurie wrote:Hi Gary,
Phil
The Federal S130 wiring diagram shows that 3rd wire (extra earth to the case).
Phil Harrison
Thanks all for your help.
Whilst clearly the motor will run fine with just the two connections, I think Bill is right about the earth providing a reduction in radio interference.
At least I know now........probably!
Gary
Gary
Gary
1972 Elan +2 S130/5
2001 Elise S2
1972 Elan +2 S130/5
2001 Elise S2
- Gazzerb
