+2 Radio Depth
Hi Chaps,
I modified my heater as well. It is straightforward, but unless you want to steam clean the matrix and completely overhaul the thing, then it really is a bit of a fag getting it out.
Just go for a mechless unit - just fits straight in,no messing.
like these ones:
https://www.caraudiocentre.co.uk/produc ... -28153.htm
https://www.caraudiocentre.co.uk/produc ... -33063.htm
oohhh this is a DAB one (need a different aerial but........)
https://www.caraudiocentre.co.uk/produc ... -32982.htm
loads here...
https://www.caraudiocentre.co.uk/catego ... ess&c=2809
Jeff 72 +2 (with a mechless head unit 50W per channel)
like these ones:
loads here...
jeff jackson - Fourth Gear
I'm interested in fit a better radio (Philps radio has bad reputation). Can someone show pictures from the heather modification?
- Dieschelan
Was looking at some old threads on this topic, and found this excellent dimensioned photo that shows the room available with the heater box completely removed. Shows how tight it really is.
The thread that has the photo is here...
lotus-twincam-f39/plus-heater-overhaul-t22942-15.html
I found several good threads on the heater modification details by going to the Photo Gallery tab (at the top of the forum page) and filtering on "Plus 2 heater". Brings up a few pictures of the process, and can easily go directly to the referenced threads.
HTH
Stu
HTH
Stu
Stu
1969 Plus 2 Federal LHD
Again, You don't need to modify the heater if you get a mechless unit.
the depth of the unit is so shallow it fits straight in.
Jeff 72+2
Jeff 72+2
