Dip/ Indicator/ horn Switch
Tue Aug 09, 2016 7:05 am
by JohnP
Hi all,
My 69 plus 2 has a combined dip / indicator/ horn push switch (right hand drive). It has sadly disintegrated (or rather the araldite the previous owner used to stick it together has disintegrated). Part no. is 050 M 6020 according to the manual.
These do not appear to be commonly held by usual suspects (SJS etc.). Does anyone know of a suitable replacement part?
All suggestions very welcome.
Re: Dip/ Indicator/ horn Switch
Tue Aug 09, 2016 9:39 am
I think it is a ford part, maybe ford Anglia 105E or something like that.
It was a long time ago when i had a 1968 +2 but i think the steering column and different things were Ford. Not Triumph as on later models
Tue Aug 09, 2016 10:08 am
by theelanman
I replaced mine with a Ford Cortina stalk........
like this one......but I didn't pay anywhere near what these guys seem to want...
http://www.ebay.co.uk/itm/cortina-mk-2- ... Sw0fhXmgYt
Tue Aug 09, 2016 10:16 am
by KevJ+2
Perhaps it's from a Mk1 or 2 Cortina. Looks very similar to this -
http://www.ebay.co.uk/itm/291829886070? ... rmvSB=trueWoops...crossover
Tue Aug 09, 2016 11:15 am
Exactly Ford 60's
Tue Aug 09, 2016 1:19 pm
by JohnP
Thanks for this chaps.
It seems Mk1 Cortina is the multi function device Mk II seems to be indicator/ or flasher. A Cortina forum has suggested an early Mini, or even a Land Rover unit. Also found something on a kit car builders website which may be suitable.
When I find the definitive answer I'll post it up, but any further definitive suggestions will be welcome.
Wed Aug 10, 2016 8:31 am
by mikealdren
It's a long while ago but I think the stalks come from a Triumph Spitfire
Wed Aug 10, 2016 9:52 am
Not from Triumph on +2 but on +2S yes triumph. On +2 is Ford
Wed Aug 10, 2016 12:51 pm
by mikealdren
That makes sense, my cars are +2S and +2S/130. Thanks Mike
Tue Aug 23, 2016 6:39 am
by JohnP
In the end it turns out it probably is a FoMoCo item- the binnacle around the steering column is stamped thus. Via a comment on a Ford Cortina restoration blog I found a suggestion that an old Mini stalk would work.
One was sourced from Somerford Mini ltd part 13H7779 for Mk 2/3 Mini. Diameter is a little big for the column but clamps on ok with some packing. Wiring matches and now back to flashing nicely.
