Starter motor and spyder chassis
Hi All
Does anyone know if you need to mod a sounder chassis or starter motor.
Car passed the MoT last week and on the way home the back left wheel almost fell off - tightened by hand and got home. Then took it to a small classic car show and on the way home the gear lever came loose.
Then went to start it this week and the starter motor is just spinning away. Looked on the forums and rocked it in gear - gave it a little tap - took a plug out and churned it over by hand and still no luck.
So then I took the starter motor out and found this. You can see that the top mount is broken.
So I thought I would just flip it round however I'm now tho King someone modded the starter motor to get passed the bracket.
You can see that it doesn't quite look like a nut will fit?
Anyone else with a spider chassis have the same problem or should it fit?
Gareth
Gareth
To get something you've never had, you need to do something you've never done!
- GHill
Thanks Rohan
Great questions.
The starter motor is this one looks like a standard Lucas lrs102?
The gearbox is definately 4 speed and is assumed to be original with an original engine.
Gareth
Great questions.
Gareth
- GHill
Hi Rohan
As always great advice as soon as I manned up and pushed the motor home properly it lined up perfectly
The car started first time and I have a new starter motor in order to replace this one so now I have an emergency replacement
Regards and Rohan thanks again always great advice
Gareth
Gareth
- GHill
