Sprint Wiring Diagram
Hi Folks
Had a look around the forum for a diagram. I can find a very good one for an S4 that I can print out at A1 size.
Is there one for a Sprint lurking about that I haven't found?- is the S4 basically the same as the Sprint.
I am changing my Dash and want to double check the wiring before I re-install it.
George
George
- Type28
Ah, not exactly. The S4 uses Lucar connectors between the dash harness and the engine harness. The Sprint uses pins with a plastic connector that is no longer available. There are a few other minor differences, but the bottom line is that they are not the same.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Symantics Phil. I thought the same when I bought a sprint harness for my S4. There were enough differences that I exchanged it for an S4 harness. If you just want to trace wires, then yes basically the same. If you are rewiring, then the answer is no.
Glen
Users browsing this forum: RichardHawkins and 21 guests
