wiring loom routing in the boot of a +2
What level of detail are you looking for ?
In my late body rhd +2, the main wiring passes along the top of the rhs of the tunnel, running in a void or slot in the undefelt. The main connections between the dash and rear looms are just inside the rhs tunnel cover piece in the footwell, although some wires do not feature a connector here.
The wrapped wiring bundle runs along the top of the rhs of the tunnel to the start of the rear seat area. Just where the tunnel starts to broaden, the wiring loom crosses over the tunnel to the lhs and runs just in front of the tank to pass over the lhs wheel arch.
Above the wheel arch and inside the boot, the loom splits. The wiring to the fuel sensors and boot light run across the tank, left to right. The remaining wiring runs down the wheel arch and then just under the boot board to the rear lhs light area, where the wiring splits again, to the lhs and rhd rear light clusters. The lhs rear number plate light is fed with wires running from lhs light cluster and the rhd number plate is fed from the rhs cluster.
Rhs and lhs are as viewing the car from behind.
HTH
Peter
HTH
Peter
PeterK - Third Gear
Interesting. I ran mine down the side of the tunnel on the floor as I wasn't 100% sure where it went. As mine is a LHD car, essentially the same as above but runs RH side in the boot.
Reminds me of an unfortunate story that confirms the loom routing I guess. A good friend got an eight track tape player installed in his Elan 'back in the day'. The installer ran four self tappers in to the top of the tunnel to mount the unit behind the seats. The car had untold mysterious 'electrical issues', until the owner realized it had damaged a bunch of the wiring!
One quick suggestion. If running speaker wires to the rear, route them on the opposite side of the car separate from the loom and well away from the main power cable.
Stu
Stu
Stu
1969 Plus 2 Federal LHD
Mine runs top of the rhs of the tunnel, not rhs of the top (does that make sense ?). Hopefully I won't manage to put any screws through it, although I was somewhat nervous re-instating the self tappers that hold the panel next to the drivers knee that fixes to the tunnel
Peter
Peter
PeterK - Third Gear
Users browsing this forum: Robhi and 28 guests
