s3 dashboard switches: another picture
here you go: i hope these were original at one time (36 / 4982) cheers - PS: my original dashboard has all the proper holes for exactly these switches (the jaguar ones are too big)
- el-saturn
PLEASE give me a LEAD! IF MY SWITCHES are wrong i'll change em withi a week!! sandy
- el-saturn
You had leads in the other topic.
elan-wanted-f4/dash-toggle-switches-t35303.html#p240854
The switches that you currently have do not seem to be automotive switches, instead they are switches from electronic equipment.
I suspect that having put a thin metal dashboard the stems of the original switches, which were for a wooden dash, were too long, so switches normally used with metal front panels of electronic equipment were fitted instead.
Have a look though this lot:
http://cpc.farnell.com/webapp/wcs/store ... rue&sf=705
thanks bill - what astonishes me most are these switches use the same female(an male) connectors as every other older car i've seen use and when i got the car, the original dash was fitted with THESE switches and even the window switches (with the welded wire crossings at the back) are a special version (up/down) of the same type of switch: the all are identical from the normal view and real nice AND always work! cheers sandy
- el-saturn
Users browsing this forum: fattogatto and 4 guests
