What have I done this time?
Many moons ago I replaced my wiring loom and had it checked out by an auto electrician. He adjusted the wiring so that I could run an alternator.
The car has been running fine ever since and all of the electrics are working fine - However - I was worried about the battery life and put a volt meter between the battery cable (by the solenoid) and earth and found that the alternator is providing a negative voltage.
I reversed the wiring on the gauge and it produces 12.5 volts
What on Earth have I done (pun intended)
Any clues would be gratefully appreciated as am clueless on electrics.
Many thanks in advance
Gavin
Gavin
gav - Fourth Gear
Hi Gavin
If everything is working fine then you dont really have a problem. The volt meter reading at 12.5V ( irrespective of which polarity you connect it) is correct in value I suspect that it is simply a case that the +ve and -ve terminals are swapped over so the polarity appears wrong.
regards
Bob
regards
Bob
- bob_rich
Hi Bob
Just been out to check again. It is possible that I misread the wiring positions on the gauge - without the engine running and the gauge correctly wired up (!), I have 13.5 volts with no electrics running.
I'll check it again with the engine running but this might just be a case of me needing new glasses !
Heres hoping.
Gavin
Heres hoping.
Gavin
gav - Fourth Gear
