Lotus Elan
Starter motor issue
PostPost by: Mick6186 » Sat Aug 15, 2015 7:58 am
I am currently rebuilding my +2 130/5 and I am ready to start the engine, which is a 1700 tall block. Upon attempting to start, with a new battery the starter turns the engine slowly for a couple of seconds then slows to a stop. I have jumped the battery to the starter side of the solenoid, with the earth directly to the engine, thus eliminating any possible earth problems. The starter is a new inertia type with a 9 tooth pinion.
Has anyone overcome a similar problem?
Mick.
Mick6186
PostPost by: dougal9887 » Sat Aug 15, 2015 10:07 am
Assuming the battery's well charged and the engine turns freely by hand, I would say you have a bad starter motor. If, like me, your 1700 has 10.5 compression and a fair amount of spark advance I think you are better off with a modern high torque starter. Transformed starting for me.
Dougal.
dougal9887
PostPost by: john.p.clegg » Sat Aug 15, 2015 11:50 am
I seem to remember that the old Joe Lucas starter motors have 4 brushes,if one of them has worn down/stuck you'd be reduced to half power,might be worth having a look..
John :wink:
PostPost by: Mick6186 » Sat Aug 15, 2015 5:13 pm
Thanks for the replies. It appears the 'new' starter motor was semi duff. I found an old Lucas unit under the bench and swopped over the pinion and mounting flange and immediate vast improvement. Now I've just got to get the old girl started. Fire extinguisher at the ready!!
Mick
Mick6186
Users browsing this forum: lotusfan and 11 guests
