Lotus Elan
Engine Bay wiring question on S1- organize better?
PostPost by: Certified Lotus » Tue Jul 21, 2015 11:39 am
I have installed an alternator in my S1 eliminating the need for the big voltage regulator. I will be installing a terminal block for the various electrical connections. The question is, who has gotten rid of the "rats nest" of wiring and made a very clean installation of this area?
Elan Voltage regulator-1.jpg and
Voltage regultor
I was thinking about removing the guts of the voltage regulator and installing the terminal block inside of it as it would "look" original installed this way. But I would like to see what others have done to clean this area up.
Anyone have photos they would like to share of what you have done?
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Certified Lotus
PostPost by: billwill » Tue Jul 21, 2015 12:10 pm
I suggest you remove the control box and fit a modern fuse block such as this one.
http://cpc.farnell.com/webapp/wcs/store ... reId=10180
It won't look original, but fitting more fuses and tidying up will really help avoid future electrical troubles. This model has LEDs to show which fuse has blown.
You may also need a small connector block to cope with the change of wiring from Dynamo to Alternator. We have discussed that on this site before, but my brain is too tired at the moment to look it up or to work out exactly what to do. Basically that fuse block has ONE input which would be from the thick brown wire from the solenoid, then it has 6 outputs for which you put in an appropriate fuse and then wire the output of that fuse to individual circuits such as headlights, Dipped lights, Horn, Cooling fan, sidelights, indicator lights etc.
At some stage I aim to put TWO such fuseholders in mine, One as above and the second for all circuits controlled by the ignition switch. The power input to the second being through a relay from the thick brown wire, with the relay controled by the ignition switch.
PostPost by: nomad » Tue Jul 21, 2015 12:42 pm
I've used the RB106 as a terminal block on a Midget and the original wiring to the alternator. Just re-route inside the regulator. The empty regulator box now contains my modified wiring diagram inside a sandwitch baggie.
Add lightness!! :mrgreen:
Kurt
26/3754
nomad
PostPost by: billwill » Tue Jul 21, 2015 7:02 pm
Heh Heh, as my eyes flicked over your message, I thought it said:
"My empty regulator box now contains sandwiches"
So I had to read it again more carefully. :lol:
PostPost by: pharriso » Tue Jul 21, 2015 7:42 pm
As a general principal I do not like to anything is not reversible or looks different than as delivered. (ok ignore the Weber vs. Stromberg head with cross over pipes... :roll: )
The instructions with RDent's Alternator conversion have you use the terminals on the now unused voltage regulator as a connector block as attached.
AlternatorInstallationInstructions_RDent_Reduced.pdf
(574.22 KiB) Downloaded 286 times
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: vstibbard » Wed Jul 22, 2015 8:04 am
I've removed the internals form the regulator and sued it as a terminal block, we had to join two of the spades. I'll take a photo tomorrow and post it, my car is nearing the end of a long rebuild currently at the trimmers.
V
PostPost by: oldchieft » Wed Jul 22, 2015 8:16 am
vstibbard wrote:I've removed the internals form the regulator and sued it as a terminal block,
V
Did it go to judgment? or was it settled out of court?
Jon the Chief
oldchieft
PostPost by: vstibbard » Thu Jul 23, 2015 10:08 am
Its judgement day had come and passed! Verdict was a frontal lobotomy!
PostPost by: Certified Lotus » Thu Jul 23, 2015 1:26 pm
Thanks for all the responses to date. I'm still trying to decide what route to take. Anyone have photos of their non-standard wiring in the area of the fire wall where the voltage regulator goes? I'd like to see what others have done.
Glen
Certified Lotus
