Larger Battery
Sat Jul 11, 2015 4:32 pm
by William2
I have often thought that the standard 37 amp hour battery fitted to baby Elans is a bit marginal on cranking power particularly if the engine is tight after a rebuild. Having done some research I think a physically larger battery with a higher amp hour rating would still fit in the available space. It would be possible to stick some 1/4" thick foam rubber sheet on the grp base area so that a slightly wider battery could be fitted. I think a battery of at least 48 AH would fit, having the same length and height as the original. Also I don't want to spend a lot of money on a hybrid battery. Has anyone done the above?
Re: Larger Battery
Sat Jul 11, 2015 5:44 pm
by Galwaylotus
Recently bought a new Exide Excell Type 063 (standard size for Elan). It is a 44 Ahr 440 CCA battery and is excellent for my car. Not too dear either.
Re: Larger Battery
Sun Jul 12, 2015 3:04 am
by tvacc
I realize you don't want to spend a lot of money, but you now have a a car worth more than 20k. An Odyssey battery 925 is like$149. Small and gives you all the cranking you will need.
Re: Larger Battery
Sun Jul 12, 2015 9:45 am
by gav
I run a rally spec Odyssey and have never had a problem.
I use a conditioner on it when not in use to keep it up to scratch.
Gavin
Re: Larger Battery
Sun Jul 12, 2015 11:09 am
by tvacc
I have spoken to the Odyssey engineers. Unless you are using a CTEK charger you are probably doing more harm than good with a conditioner. It is best to leave it fully charged, disconnected. And the colder the better. Should last for years that way.
Re: Larger Battery
Sun Jul 12, 2015 2:58 pm
by webbslinger
I've been using a little Odyssey 680 with no problems. I did get a smart charger with it and occasionally top it off as the voltage from my alternator is marginal when running with the lights on. The 680 works great for me.
Re: Larger Battery
Sun Jul 12, 2015 5:44 pm
by tvacc
Yes, the 680 will probably work fine. I have a 71 Elan and the 925 fits in there so that is what I used.
Re: Larger Battery
Sun Jul 12, 2015 10:10 pm
by mark030358
I have an Odyssey battery fitted, went straight in. Just disconnect after a good run and it holds its charge.
Magic piece of kit.
Re: Larger Battery
Wed Jul 15, 2015 9:07 pm
by l10tus
I thought the OEM was an 037/8 battery ?
Re: Larger Battery
Wed Jul 15, 2015 9:12 pm
by Galwaylotus
Oops! Probably right. There was a type 063 in my car when I bought it and I didn't check to see if it was standard. It works just fine anyway.
