wiper motor gear Sweep degrees
Hi does anyone have an S1/2 or 3 wiper motor out of your car? If you do, would you be able to do an simple check of the degree marking on the main gear which is under the pressed metal cover with 4 screws holding it down?
Im testing one installed in my S1 that is nearing end of its rebuild and the wiper arc seems to be wrong. Sadly I dod not note the figures and if wrong I have yet another dash pulled down job to face!!
Vaughan
Vaughan
- vstibbard
Vaughan,
On my S4 the sweep is 110 degrees as stamped into the main gear.
Hope this helps you.
- everettmse
My pre-airflo FHC wiper assembly is on the bench beside the car, but I'm 900 miles away. I may be back for a short visit over the summer, but more than likely, it'll be November before I'm back to check on the car and finish it's restoration. But you probably don't want to wait that long.
Seems like some of the old Lucas parts books have data on wiper gears. I'll look to see what I can find.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
When I fitted a new motor into our S3 I used a 110deg wheel. Seems fine!
RogerFrench - Fourth Gear
