Window Motor Switch Wiring
I am in the process of rewiring my S4 dashboard and the only problem I have come across so far is how the wires connect to the window motor switches. I am using the workshop manual and a diagram of the switches as viewed from behind in Gordon Lunds book. It appears that Gordon's diagram for the wire colours is different to the manual wiring diagram and the loom itself. I trawled through the relevant photos on the forum but couldn't find any drawing or photo to help. Any help would be much appreciated.
- William2
William,
This is what I drew when I changed my dashboard. Note that my Elan is LHD, so the driver's side will be opposite for you.
Noting the Driver's side for all the switches was not electrically relevant but it helped me visualize things, especially for the switches that are not symmetrical. I was being super careful!
The Red/White to the Courtesy light can piggy back to the Brown wherever it's easiest.
Nick
Nick
elanner - Fourth Gear
Is this thread of any help?
lotus-electrical-f38/switches-anyone-repairde-them-t18014.html#p95916
The window switches have 6 terminals each. I decided to use relays to take the load off the switches. My, that took some research! I have ended up with four changeover relays and it all works beautifully.
TroonSprint - Fourth Gear
Users browsing this forum: lotusfan and 28 guests
