Lotus Elan
Coil lead
PostPost by: GHill » Sat Jan 24, 2015 12:34 pm
Hi All
Can someone please confirm whether my dizzy to coil ht lead looks correct - I don't think so? The picture below shows the coil end and it just looks strange! I would have expected a plug type connection!
Gareth
image.jpg and
Dizzy cap lead to coil
image.jpg and
Sports coil
To get something you've never had, you need to do something you've never done!
GHill
PostPost by: billwill » Sat Jan 24, 2015 1:05 pm
Never seen one like that.
Looks like it might be a resistor.
PostPost by: GHill » Sat Jan 24, 2015 2:25 pm
Thanks Bill
I'm new to all this - can you give me a little bit more context please? For example is there normally a plug?
Gareth
GHill
PostPost by: billwill » Sat Jan 24, 2015 2:33 pm
Mine has a sort of split brass tube with inward pointing spikes which has been squeezed onto the end of the cable to form a sort of plug.
PostPost by: GHill » Sat Jan 24, 2015 2:58 pm
Does it look like this?
image.jpg and
Thanks Bill, lovely engine bay btw
GHill
PostPost by: jimj » Sat Jan 24, 2015 3:04 pm
You need one of these; http://www.ebay.co.uk/itm/HIGH-QUALITY- ... 462c6180b6 . It probably worked OK with the chewed up end making a contact as it was, but maybe not for long.
Jim
PostPost by: GHill » Sat Jan 24, 2015 3:20 pm
Hey Jim
Thanks - isn't that what I've got already? How does it work, do I put the copper wire next to it - or somehow overlap it to get a good connection?
Think it works like this...
image.jpg and
Connector
Gareth
GHill
PostPost by: types26/36 » Sat Jan 24, 2015 3:36 pm
GHill wrote:Thanks - isn't that what I've got already?Gareth
Yes the one in the ebay link is the same as yours but it has been fitted the wrong way round on your cable, you bare the wires and then pinch them with the tagged end of the connection.
They are a rubbish fitting, the one that screws into the cable (later picture) is a much better type.
types26/36
PostPost by: GHill » Sat Jan 24, 2015 3:39 pm
Thanks Brian - I prefer the screw fitting - it strikes me as a much better connection.
Just ordered this from ebay
image.jpg and
Gareth
GHill
PostPost by: types26/36 » Sat Jan 24, 2015 4:18 pm
Yes they work fine, some distributor caps also take that sort of fittings but if you have the original Lucas type it uses a screw inside the cap to go through the ht cable so you wont need more.
types26/36
PostPost by: billwill » Sat Jan 24, 2015 6:20 pm
I just buy the leads ready made in Halfords.
That wasn'y MY engine bay bye the way. :o I merely did a search of the picture gallery to find a picture that showed the Heating valve.
PostPost by: GHill » Sat Jan 24, 2015 10:03 pm
Cheers Bill
You've just taught me that you can search pictures - an enlightening day all round! Thanks
Gareth
GHill
