Washer Switch/Pump
Thu Dec 18, 2014 2:17 pm
by KevJ+2
Has anyone used a Triumph GT6 washer pump / switch to replace the (almost) unobtainable original?
At ?25 it seems good value, but would it park correctly and take the same wiring?
The item number is 155495
http://www.jamespaddock.co.uk/parts.asp ... her%20pump
Re: Washer Switch/Pump
Thu Dec 18, 2014 4:31 pm
Educated guess,yes,but what about the knob?
Thu Dec 18, 2014 5:18 pm
by KevJ+2
I guess item 704875 or 609946 from the same site. I seem to remember someone on here saying these were good alternatives
Thu Dec 18, 2014 7:12 pm
by sveris
Is this one the same as the ones used on later Europa Twin Cams with the electric washer pump?
Steve in Ohio
Thu Dec 18, 2014 7:22 pm
by KevJ+2
No Steve, this is a push manual pump combined with a turn-2 speed wiper switch.
Kev.
Fri Dec 19, 2014 5:06 am
by sveris
So, it's the one with the diaphragm that so often goes bad after all these years? As used on the earlier S2 Europas?
Steve in Ohio
Sat Dec 20, 2014 11:15 am
by tablets32
Bought one of these yesterday, also bought a new knob to match. The whole thing fits well and looks the part.
Keith
Sat Dec 20, 2014 1:22 pm
by KevJ+2
Excellent Keith, could you tell me the correct part number for the knob.
Kev.
Thu May 07, 2015 2:08 pm
by tablets32
Hi Kev
So sorry for the late reply. I bought switch and knob from James Paddock, there is a choice of two knobs I went for the round one. Have a look on their site.
Keith.
Thu May 07, 2015 2:41 pm
by KevJ+2
No problem Keith, I too bought one from James Paddock, then luckily amongst all the mess in the car, I found the original knob. I'll be putting the dash back in shortly to try it out.
Kev.
Sun May 31, 2015 8:14 am
by vstibbard
Hi hoping someone can help me, what type of nut did you use to secure the switch, I'e just purchased one and its a different diameter to the old switch.
Vaughan
Sun May 31, 2015 10:08 am
by KevJ+2
Vaughan, I asked the same question on here in another post and nobody knew. I also asked James Paddock who was clueless and I also hunted around an engineering stores with no joy. In the end I recut the thread for a large unc nut but with the recessed chrome fitting that goes into the dash wood, it was all a bit of a fuss.
Good luck,
Kev.
Wed Jun 24, 2015 1:07 pm
by vstibbard
Thanks I had one cut so it would fit the cup it has same tightening method as some lucas switches with the two slots at 180degrees to each other.
V
