Lotus Elan
Wiper Motor Mounting
PostPost by: Hugh2654 » Sat Nov 29, 2014 6:04 pm
Hi Guys,
My Plus 2 has a steel plate which the wiper motor is mounted onto. The plate is bolted to the body with the nuts being undone in the passenger foot well. It is rusted beyond repair. Does anyone know where to source a replacement.
Hugh2654
New-tral
PostPost by: Lotus fan » Sun Nov 30, 2014 10:07 am
Usual suspects !!
A quick phone call will get you a new one :D
Lotus fan
PostPost by: KevJ+2 » Sun Nov 30, 2014 11:29 am
Very easy to make this yourself with an angle grinder mild steel and a drill.
Kev.
KevJ+2
PostPost by: ncm » Tue Dec 02, 2014 3:58 pm
My early plus two uses a steel pressing, may-be later cars have a flat steel plate that would be simple to replace?
Cheers, Brian
P6130124.JPG and
plate viewed from passenger footwell
PostPost by: Hugh2654 » Fri Dec 05, 2014 1:29 pm
Hi Brian,
That's the same type of plate on my car. Apparently they are nor available so I will have to just have to make a flat plate instead. Bit of a shame because I was hoping to keep it as original as possible.
Hugh2654
New-tral
