what coil to fit EI
if you remove the ballast resister and ballast coil to fit a normal coil what one is best.
I plan to fit Piranha Electronic Ignition and a 12V coil with 1.5 ohms to 3.0 ohms resistance.
I understand it is best to fit coil with at least 1.5 ohms resistance so as not to damage the EI.
open to ideas
open to ideas
Alan.B
- alan
I'm using Powerspark ignition and got a similar suggestion from them. I have a Lucas Sports coil with 2.8 ohm primary resistance and 8.7k ohm secondary. A new "standard" coil has 3.4 ohm primary and 6.7k ohm secondary. I had each of these in my stock of spares and measured each straight out of the box at normal room temperature. Hope this helps!
'67 S3 SE FHC
'67 S3 SE FHC
Users browsing this forum: GLB and 23 guests
