Lotus Elan
S2 Dash (red) warning light
PostPost by: CG901 » Tue Jul 01, 2014 10:24 pm
I can't find this warning light on the S2 wiring diagram or S2 dashboard layout. I have a red lens directly under my oil pressure / water temp gauge (LHD far left side of dashboard) with black and green wires. Anybody know what this is? I can't get it to light up, and the filament in the bulb appears to be intact. If it has no use, I will use the hole for a toggle switch operating a cooling fan. Thanks.
IMG_5387.JPG and
Current: 1965 S1.5 26/4004, 1966 S3 FHC 36/5192, 1958 Fiat Abarth 750GT Zagato, 1967 Brabham BT21B, 1988 Arrows A10B-04, 1991 Brun C91-001.
Past: 1971 Elan S4/SE DHC, 1972 Europa Special, 1980 Esprit Turbo, 1988 March 881-05, 1990 Leyton House CG90105
CG901
PostPost by: types26/36 » Wed Jul 02, 2014 2:16 am
Isn't that the handbrake/emergency brake warning light ?
types26/36
PostPost by: CG901 » Wed Jul 02, 2014 2:22 am
I see a 'handbrake warning light' on the S4 dash in that approximate position, but not on the S1-S3. This is the only light on that side of the dash.
CG901
PostPost by: types26/36 » Wed Jul 02, 2014 2:37 am
Both my S2 and S3 have the h/b warning light in that position (right hand drives) also have green and black wire........also my Sprint.
types26/36
PostPost by: CG901 » Wed Jul 02, 2014 3:23 am
OK, thanks. Seeing multiple versions of the S3 wiring diagram, with one showing this handbrake warning light. Must have been optional on the S1 with their smaller dash.
CG901
